MaxLaMenace
- Jan 13, 2016
You heard right. I've just tried inserting one 128GB and one 32GB card, and it only detected the card in Slot 1 (128GB).
That's really dumb, but I'm sure they will fix it in the firmware update ASAP if they don't want to see a million angry e-mails.
There are lots of minor bugs they need to address, but this one is a major one.
You could be right. There is definitely something wrong with the way DX80 handles the SD cards.
I tried Sandisk 128GB formatted with Fiio, Windows exFAT and Macintosh FAT32, and in all cases the music files show up and plays songs, but scanning fails (I just placed one album with 6 songs, and DX80 only detected 1 out of 6 songs in the scanning).
Also, DX80 connected to PC as "storage" mode shows 32GB card fine, but fails to show 128GB card (both on Slot 1), irrespestive of FAT32 or exFAT.
Once the scan fails once, it fails every subsequent time (even on 32GB card, it crashes scanning half-way through, followed by a loud relay "click"), and nothing gets updated until I do a Factory Reset (which I've done many times already).
e.g. I have this bizarre repeatable bug where upon factory reset, the system asks me to rescan the 32GB SD card. When I say YES, it freezes at 63% and needs hard reset. When I say NO, and then do a manual scan later, it completes 100% and everything is well.
Overall, DX80 simply seems picky on SD card reading, and crashes with slightest of errors, rather than handling them gracefully. I just want to know a sure way of getting it to work, which I'm sure everyone else would benefit.
Hey !
I have just spoted this post and I have exactly the same issue with my FAT32 Sandisk 128g (I first thought it was linked with a tagging problem). I am using FW 1.2.1 and I have this odd bug : "it crashes scanning half-way through, followed by a loud relay "click" ".
Do you guys have some fix for this bug ?
Regards,
