CoiL
Member of the Trade: Wood Audio Accessories & Modifications
Just got new opamps installed.
HO opamps (2x ADA4897-1ARZ)
LO differential opamp (ADA4841-2YRZ)
Firstly I want to thank BABS for all the info he has provided, all the help and recommendations - BIG BIG THANKS TO YOU!
This time I think I have found sweetspot and best SQ I could get out of DX50. This is simple stunning SQ out of this little black "box" !
Opamp upgrade has improved midrange clarity&details (while not making it thin), soundstage, imaging, layering, details and
most important - bass tightness/details/thump/resolution... by a quite big step!
Also, it seems there is more power output on HO. Before HO @ high gain seemed to boost mainly lows and highs but now it "boosts" everything evenly and is more powerful.
_________________________________________________________________________________
Final setup:
Firmware: Sound Unlocked 1.3.3 - settings -> FLAC only/ IIR off / CPU default
Hardware upgrades:
HO decoupling cap - Panasonic POSCAP # 10TPE220MIL (7343 case)
DAC differential amp decoupling cap - Panasonic POSCAP # 6TPE100MI (7343 case)
DAC analog power supply decoupling caps - Panasonic POSCAP # 6TPE100MI (7343 case)
HO coupling capacitors - 4x Panasonic FC 220uF 10V # EEUFC1A221S
LO capacitors - 2x Panasonic FC 100uF 10V # EEUFC1A101S
HO opamps - 2x ADA4897-1ARZ
LO differential opamp - ADA4841-2YRZ
This setup is now clearly over my modified Aune T1 desktop rig. It`s quite absurd how much money I spent on tube-rolling and upgrading its HW compared to DX50.
This modified DX50 setup is highly recommended by me and if someone is planning on getting new DAP just to get better SQ - I strongly recommend considering modifying DX50 before.
I think I will call my DX50 as DX5X from now on.
I just realized that my upgraded HO opamps have 80mA output current per channel - that`s why my low impedance ZS5v1 sounds so great with thumpy-tight-fast-detailed bass&percussion!
Going to try POSCAPs (10TPE220MIL) soon instead Panasonic FC HO caupling caps, just curious if it will improve since I haven`t tested those yet in that position.
Also, had to repair HO jack, pins came loose. Thought about changing it out for gold-plated but after resoldering it is tight-fit again, like new.
