xnuthecaveman
- Mar 28, 2012
If I remembered it correctly, R10 uses a different configuration of 5V compared to dx100's 8.4 V
I just changed one 4800mAh battery, two battery series connection,3.7 x 2 = 7.4V, and all is fine.what's the biggest capacity battery DX100 can use?
I got 3300mAh but I'm sure it can use larger batteries...
DX100's original batteries were manufactured in 2011.
Now it's 2019.... and there are larger capacity lithium batteries.
3.7v x 2 = 7.4VIf I remembered it correctly, R10 uses a different configuration of 5V compared to dx100's 8.4 V
http://www.fidelizer-audio.com/tag/dx100/
Any DX100 fans tried this?
Sure the UI feels smoother with the Fidelizer Audio "Purist ROM" version, but the SQ is a major downgrade to me. Sounds less musical, harsher, brighter in the high range, and boomier bass. Based on iBasso FW V1.4.2, so I guess that was to be expected, but I'd just forgotten how bad that firmware version was! After testing for nearly and hour, I decided I couldn't take it any more, so have reverted back to iBasso's FW V1.2.7., and thank goodness, aural bliss is back.I did the update on my R10 a couple days ago and posted brief impressions here:
https://www.head-fi.org/threads/i-b...ressions-thread.607423/page-109#post-13934359
So I'm going to give this DOC2008 Optima Mix V2 FW a shot now, since that one is supposed to be based on iBasso's FW V1.2.7.Finally the perfect 1.2.7 FW for me at last; 1.2.7 without the annoying media scan:
DX100 V1.2.7 OPTIMA MIX BY DOC2008 V2
https://yadi.sk/d/M71HYIzLhAbgD
Hi guys,
I made some mistake, then my R10 keeps restarting and I'm unable to factory reset. I try Power + Volume up but it only shows a tiny green android and a yellow triangle.
Any idea how to fix that?
Thank you
I think you will need to use PC to reload the firmware using the android debugging software.Hi guys,
Thank you
does this fidelizer thing actually change audio? audio should never change, it should be directly fed to dac (dac supposed to produce audio...).I recently purchased a couple of daps namely thr hiby r5 and thebitopus3 so was ready to let go of my DX100 which I bought off the original owner about 6 years ago,
decided to update to the latest free fidelizer rom and wow ,dap has never been better,it loads my 64gb in seconds and plays beautifully.
I changed my router recently and wifi on the device is now a lot stronger and the spotify apk for gingerbread plays without any problems(no art). as
I also use VLC which is great but as soon as I load poweramp which I had purchased in the past it says my trial period is over(any ideas).
I am going to purchase a new battery , of the best daps made
Im tempted to install this fidelizer rtom but i only want speed upgrades in ui, audio should be unchanged.
