temporaryname
- Jan 17, 2011
Thank you for communicating these issues with them. Hopefully they'll bring out a fix soon enough. They've been pretty good with that sort of thing so far.
No way this is a finished product I'm afraid... Have you made a playlist yet? Absurd, that it lists as plays in reverse order. Having to make them up in reverse in Media Monkey and transferring is a complete pain in the a#%e. then there is the random play stopping when it goes to sleep, or the click when you wake it up. But I am not just complaining here. Others have written that iBasso listens so I have sent the following to them. Others should do likewise so they hear us...
Hi,
First up, really liking my DX100. Great sound for any music I play. But there are a couple things which need your attention.
1. Just updated the firmware to 1.3.5. Playlists play in the reverse order to their track listing. This makes it impossible to create a playlist of almost any music. For example any album that embraces two or more CDs, eg Pink Floyds The Wall, I would make into a playlist so the entire album plays without interruption. Why on earth would I want it to play in reverse order? And making up a classical playlist? Forget it. Guys this must be immediately corrected.
2. From time to time the music just stops playing a short time after the screen sleeps. Wake it up and it recommences playing. This also happened on 1.2.7. If I restart the DX it seems okay for a while then randomly the problem comes back. I did a factory reset but that has not fixed this problem.
3. I hate the load click that invades my ears when I awake the DX100 if it has been asleep press the wake button. Can't this be fixed. Such an expensive player should not do this. It's not in keeping with the quality of the device other than these few niggles.
Please fix the playlist with an update immediately if the other two things may take a little longer. It's an absolute pain to make up playlists to overcome your mistake. But al three of these things get much comment of Head-Fi but you're probably aware of that.
Thanks in advance for fixing,
My issue in point 2 just happened again while I write this. It happens whether listening in the simple or advanced player mode. Doesn't seem to be like some others symptoms here. No other apps running in background... Going to try whether the exit from the advanced UI works and if there is a relationship to reaching the end of an album.
Hope iBasso fix these quickly and don't take a few months waiting for the next major firmware update.
