DannyBai
- Nov 21, 2010
DX100 will not play AIFF files, correct?
My flacs have only the flac or vorbis tag added via mp3tag, I don't see any way of adding v3.1 or v3.2 tags but thr DX100 doesn't even use the tags right now, instead it uses the filename for the title and the folder name for the album, totally ignores embedded art etc. Has anyone managed to get flac tags recognized, if so how?
When I have my customs in and when the player goes into sleep mode and I turn it on again, the pop sound is ridiculously loud and startles me every time. It scares me that it could ruin the customs if not my hearing first. An extreme flaw IMO.
So when you check mp3 tag does is say (FLAC)? I thought those were the v3.1 tags. If you have v3.2 it will say 3.2 next to the flac meaning you have more than one tag on the file. What I did was have mp3tag read v3.2 v3.1 and have it remove v3.2. Then you remove all the tags. Then click undo. It will restore all your tags but v3.2 and whatever else you've chosen not to add.
English please.
So you're saying DX100 doesn't read v3.2 tags, so with mp3tag, remove 3.2 and retag all my flacs with 3.1...? Does it do this automatically?
Wait to you hear them...they will put STAX to shame....yep I have some land on...
What's pissing me off even more is the "Sorry!" and error pop ups, and how mp3s stop playing altogether after the song's over and I have to restart the device to get it working again.
can I ask where you got your Senn Amperior's from with the custom cables?... I've had mine on pre-order for over six weeks now & Sennheiser are still not stating a release date.
PowerAmp isn't giving me any issues whatsoever; all tags are working on there. I don't know what's up with the stock player but I'm backing up all my music right now and am going to do a full reset.I'll let you know what happens. (I tried the v3.2 to v3.1 conversion. It's still not working.) Hopefully the reset will fix the issues, especially the mp3s stopping all of the sudden.
Now to find a way to make .m3u playlists to make life easier...
I use media monkey to make playlists and point the m3u files to a folder of my choosing for permanent archival as I will not go through this BS of creating playlists again. Only when I'm adding will I do this. Then after I set up medimonkey auto sync where it syncs the playlists just as they would appear in the directory (making it very easy to add and remove files on the fly).
Whats nice about the playlists is that they will be in the order of your choosing regardless of the file number.
Also if its not to difficult could you post a screen shot of some of your files in Mp3tag for me to see. That could help me help you out.
When you do a factory reset it will not delete your music BTW. Are you intending to do a complete format as well?
