lee730
- Jan 9, 2011
Holy crap getting iTunes playlists in sync on my Mac has been close to impossible. Every single program I've tried has had ONE critical error, each different.
Clementine: Renames the files when it copies them, so I can't just fudge the file paths in exported playlists.
TunesSync: Skips ALAC files (even though they can be played). Almost all the 1000+ files I want to copy are ALAC.
Winamp: Errors on trying to read my iTunes library.
Songbird: Claims my DX100 isn't in USB Mass Storage mode, when it is.
Can you use Media Monkey to bypass itunes? I use to do this for my iphone4 as I hate itunes with a passion. The crappy part is you may have to remake your playlists. You could copy and past the playlist files into specific folder (basically name the folders what you would name your playlist) and use the directory to play these folders as playlists. I do this on my DX100 and it works good (at least using Power Amp). The Stock player has some glitches that need to be worked out still. But you can access your files via the directory on the stock player. Just it skips to other songs on the player and doesn't stay on the current folder selected..
