H20Fidelity
- Feb 11, 2012
when something is good, what more can you say aside from praising it.
when something is bad, what more can you say aside from criticising it.
lows: excellent subbass rumble 10/10
mids: transparent and detailed 8/10
highs: not grainy at all, well extended 9/10
soundstage:above average 8/10
details: above average 8/10
fit: for me 10/10
totl level: 9/10
price to performance ratio:10/10
impedance: low very easy to drive
case: quite wierd 7/10
stock tips: an assortment 8/10
cable: great 9/10
I've noticed it a little mate recently, people are trying to tell you something, they're becoming a little agitated how to go about it. I think maybe if you can slow down a little and be a little more constructive with your posts, form a little stronger foundation behind them. Say why you think they're great, what part of the sound, build etc makes you feel that why.
I don't personally dislike you, I want to help you. Because what can happen if it continues is you'll ruin your reputation, and once that happens people won't believe a thing you say. I'm trying to help you, not hurt you.
