Lurker0
has anybody tried the spinfit tips?
If you search the thread for "spinfit", you may find my successful story.
They fit well. I have the smalls. Word on the street is the it03's are made for foams though...Or wide bores. I'm going to buy some auvios and I'll post on how that goes. Spiraldots didn't do it for me.
Thanks, I found your post on this. I bought the Spinfit M and L CP100s as well but thought I would try the stock tips to determine what works best for me, then listen a while and try the Spinfit. Just looking at them in the package it appears the bore hole is not as wide as the stock tips so without listening yet, was concerned they would alter the tuning.
Have you tried any other tips besides stock Spinfit?
Imo spin fit and comply change the sound too much. I use Sony hybrids on my iT03 and really like them. Usually I like spiral dots as they just get out of the way and let the iem do their thing, and the Sony pushed right down don't cover the iem at all. Very comfy too.
Good info, because I definitely don't want to alter the original tuning. I may order the Spiral Dots and also give the Sony hybrids a try. This is what I found on Amazon, Hybrid Replacement Set Earbuds Eartips for Sony XBA , MDR and Dr Series In-ear Earphone Headsets, 12 Pcs S/m/l. Would that be correct?
There's a large difference between brand new Spiral dot and an old pair that I had from my JVC HA-FX850 (about 3 years old).
The old pair is a bit distended and tends to come off too easily. The new pair fits nicely.
Unfortunately, silicon doesn't last forever...
Where is the best place to purchase the spiral dots, ebay sent from Japan?
