BoogieWoogie
- Dec 1, 2009
Like dynamics depends on the model. You can grab the SR-Lambda or SR-Lambda Pro plus the amp for around 500$, maybe to much ? There are cheaper models
There are also DACs under $300 like the V-Dac although for a bit more you can get the better DacMagic.
Crispy...
yummmm...
I heard that grados need long burn in proccess. I cant say for everyone only for me. I heard both cans used a lot of time so probably burned in perfectly. Even I read those stories before I heard completely no sibilance from them. RS1 were not such aggressive as 325is, more smooth, more magic. I believe RS2 are even more enjoyable from what Ive heard. I had RS1 few days ago at home and they played very good from Matrix M Stage. B
ut I just felt magic from that little box - DIY amp made by Majkel:
I also suggest you to buy used pair to find its signature. if you find it sounding harsh to your ears you can sell it without loss.
The HF2 I had wasn't sibilant as long as the recording wasn't. I think of all the headphones listed the Grados are the ones that will have the vocals the way you want. The 325is is the brightest of the Grados and to some, me included, can be shrill ans piercing. The HF2 and RS1i are much smoother. There are amps that can be found on Head-Fi for around $3000. Like the Gilmore Lite. There are also DACs under $300 like the V-Dac although for a bit more you can get the better DacMagic.
FWIW I found the ($100) Zero DAC sounded better than the DacMagic... really all op-amp based DACs are going to sound pretty much the same as they're all built around $10 op-amps. I'd suggest making do with what you have until moving up to something completely discrete.
Thanks for the advice m8, but im having a small problem here, ive been trying to find a site that ships a Grados RS1 to dubai, and all of them dont D:, this is a first for me ._.
Would it be possible for me to ask the person who i buy the amp from, to ship an RS1 alongside the amp? with me paying for it ofcourse :0.
I still don't get why there isn't any Audio Technica recommendation see OP wanted some vocal centric headphones. AD2000, A2000X, W5000, W1000 all does vocal exceedingly well with a slightly different taste on each one.
Quote:Originally Posted by Adamora
"If i was to buy a grados headphone, aka the RS1, what $300-400 amp goes well with it?"
Here are a few that I've liked:
Gilmore Lite (dynalow)
M^3
M Stage
Headroom Micro Amp
iBasso D2+ Boa
