Music Alchemist
Pokémon trainer of headphones
- Dec 17, 2013
Ok, I said I was thinking about a tube amp for work, and a solid state for home.
I also said that my combined amp/dac budget for work and home is about $2000. Music Alchemist, no offense, but I'm not sure you're reading what I'm actually writing.
Yeah, I misinterpreted some of what you said. When you said $2,000 for everything, I thought that meant including the new headphones. If you can spend $2K on amps and DACs, and also afford to get the T1 and LCD-3 not much later, that could get you some great gear.
So did you want to buy multiple DACs for home and work as well? Or perhaps use the same one, bringing it back and forth, or use no DAC at all at one location?
With your budget, it may be a good idea to buy various things, compare them, then return what you don't like as much. (Though that won't tell you how you will like it with future headphones.) It would also be a good idea to compare with and without a DAC in each system, to make sure you hear a difference.
