bogi
- Mar 16, 2013
I'm using gauss-xla and there's a 5-6 second delay across the board. At 768k there are constant dropouts (3-4 per minute), at 384 almost none, but the lag is still there.
I don't think more RAM is needed for xla. Rather faster CPU clock for 768k.I'm hoping/guessing it's a RAM issue because my mini only has 8gb and I have 32gb on order. The mini is a 2018 with a 3.6Gb quad core i3, I would think this is plenty of cpu power for PCM?
You may yet try other USB cable or port, or for example Topping HS02 galvanic isolator.
Try different 'Buffer time' in Settings -> Outputs and 'Blocks per cycle' in Settings -> Advanced.
