wjp007
- Feb 23, 2013
I just did this. I used silicone from Smooth On. I got a two part clear silicone kit. For my mold, I follow the same process as an acrylic. I use krystaloid that I bought from lightning enterprises for my mold material. I then make a hole in the mold where I expect to put my sound tube. I insert my driver in the mold putting the sound tube through the hole I made. Once I have my headphone wire and driver lined up properly, I pour in the silicone mixture in the mold and let it cure. The hardest part is to get the driver lined up in the mold to make sure there is sufficient clearance on all sides. The krystaloid works great as it's fairly slippery and doesn't stick to the silicone.
