vector1
- May 28, 2014
Where is the nozle on shell? Is there enough space for crossover components? Also you can skip the tubing and integrate them into shell , just the Westone4 or shure iems.
Here you go, the latest iteration of my design.
I tested it out with a 0.75mm wall thickness and it's nice and transparent!
The no tubing idea was already in the works, and you can note the "boot" fitting into a smaller notch, and the drivers held in place inside. The CI is offset about 3mm behind the WBFKs and 2mm behind the DTECs so I can push a red filter in there if I want.
I'm using tiny tiny resistors/capacitors (1206 SMD) size which are about 3mm long, so no worries about fitting a whole crossover network inside if i want to. There's plenty of space behind the WBFK on the opposite side.
I need to ask, what happens if the metal cases of the drivers are in direct contact? There's no electrical interference/grounding going on right? Also, what diameter nozzle should I choose? I'm currently using a 3mm nozzle with 1mm inner diameter for extra strength. Which is most compatible with shure olives?
I'll try to get some photos of the semi completed IEMs tomorrow when I print this copy.
