lee730
- Jan 9, 2011
Hi Lee
I PM'd you dropbox link to 3 FLAC files so you can have a look.
And here's the screenshot you wanted .....
Click for a bigger image.
Thanks for the link to the firmware files. The ones posted in that thread are a lot older though (and none state they are for the V3 - just the standard Studio). Jack mentioned to me in an email that I should stick with the current one on my player - and to be honest, I'm getting accustomed to the 3 minute wait on boot. The last thing I want to do is cause issues when the sonics are so good with what I have.
I may prune a few more albums from the current ones I have loaded - which will also speed things up.
To my knowledge the Studio BA and Dynamic firmware on that thread is the most current (stable) firmware available. I'm not sure if you are using the newest firmware (which I found to be too buggy to use). That is why I mentioned getting the firmware from there. I got my current firmware from that thread and had no issues loading it and reverting between the BA, Dynamic and even the newest one that Jack had provided me. Just I reverted back to the older one as it worked better. I could scroll down by just holding the button instead of having to press each time to scroll down to a particular song (very annoying....).
Anyways I checked the files you gave me. The only thing I can really think of is that you need to get rid of the dashes in your filenames. Such as 01 - Gloria. Instead make it like this 01 Gloria
That is how all my music is tagged. You can do this on the fly via mp3tag. I put the presets into my guide so you just enter them into the mp3tag tagging icons.
You can also configure mp3 tags buttons to do auto changes on the fly for you.
Under the "Tools" tab you'll notice 4 buttons with an arrow pointing to the right.
For the first one click it and copy and paste this: %track% %title%
Second one: % track% %title%
Once you input that you drag and drop an album to test with. Simply hilight the files and click on the first icon which will automatically take the track numbering and the title and combine them for your filename. You can also have all tracks that are listed as 1,2,3,4 automatically renamed to 01,02,03 as long as you have the files in order from 1,2,3 on the fly. I'm sure you have done that part from the looks of the files you provided me though. Other than that the only other thing I can possibly think is that you could have some weird characters in your song titles? Possibly very long song titles as well?
Let me know if that helps.
