Music Alchemist
Pokémon trainer of headphones
- Dec 17, 2013
Time to take it to sound science.
Yeah, well, we can't conduct a proper investigation otherwise, can we?
I believe the more headroom in the high resolution sound allow for more instruments, notes,tones to be played and recorded. I don't think there is a point to test listening high resolution from a track of 3-4 instruments with wasted space...it will result in more noises when recorded at 24/96, and most of the time these noises can not be heard unless you pump the music loud enough to blow out your ears. Hence I will commit finding a better recording sound track to test it myself.
The investigation is just as biased ( in which particular direction depending on your personal perspective) regardless of where it's posted. It just gets observed and participated in by the correct parties in sound science. It's common courtesy as outlined in the rules so portable source gear threads stay about portable source gear. Doubting what another hears is also frowned upon other than in that forum.
"If what you want to post includes words/phrases like "placebo," "expectation bias," "ABX," "blind testing," etc., please post it in the Sound Science forum."
"Discussion of blind testing is only allowed in the Sound Science forum." http://www.head-fi.org/a/terms-of-service
Just a heads up. I'm not reporting or further participating. I wouldn't have posted this if you didn't respond to my polite reminder.
OK, just so you're aware, I know enough. Unless you have the best kit in the best environment, it's always relative when actual listening is involved. Problem is you could have a decade long discussion on what constitutes best kit or environment in the same old sound vs specs format. It's an endless circle driven by personal opinion and experience. Scientific process remains a constant but experiments can be setup to more easily fail or succeed depending on parameters. It's a lot less linear when it comes to sound. For instance, if we're lucky, we can hear to 20Khz but we can differentiate as little as a cent or 2 in time of a midrange frequency when it's a differential or harmonic. Can 16/44 reproduce that sort of time differential? Maybe there's more to it, maybe not but being the only objective guy in the room is probably not the answer.
I honestly think it would be cool if high-res sounded better than Red Book when the files are from the same master. It's just that no one has ever been able to demonstrate such a thing.
Correct, you can't get 24kHz tones on CD, and you also can't hear them ^_^
I always thought they need to increase the frequency so that they can increase the sampling rate due to theNyquist–Shannon sampling theorem.
Yes if you want to capture a frequency greater than 22.05kHz you need a sampling rate greater than 44.1ksamp/sec. But there is little evidence that humans in general can hear (at least with their ears) higher than 20kHz. The slightly higher sampling rate for DVD/Blu-ray (48ksamp/sec) I believe is tied more into syncing audio with video more than it is with a need to generate a 24kHz tone. I mean it's easy to experiment. Make a 48k file of a 23kHz sine wave and see how well you can hear it / sense it through headphones and speakers.
My point is we want a higher sampling rate therefore we need to increase the frequency range, otherwise we can't preform fourier analysis on it to turn it into 0 and 1s. 24kHz is just due to the sampling rate we want and still want it to be digitized, so the point is if humans can tell the difference between the sampling rates and NOT hearing extra sounds at 20+ kHz that has been suggested.
Fourier analysis doesn't turn the waveform into 0s and 1s, it takes a waveform from the time domain to the frequency domain and vice-versa. In the case of digital audio, the waveform will be discrete (having already been turned into discrete data by the ADC) and assumed to be periodic, and thus the frequency representation will be periodic and discrete.
You are reversing the logic a bit: we don't chose a frequency range to get a sampling rate; we chose a sampling rate to get a frequency range. All differences between PCM formats at a given bit depth are due to the sampling rate; there's nothing else that is different! So for instance the faster rise-times for transients that 16/96 PCM has over 16/48 PCM is entirely due to the extra frequency content (24-48kHz) allowed by the higher sampling rate. And you can't hear those frequencies, so ask yourself how you are possibly sensing something like these "better" transients.
