still no feedback if Serenade is now TIdal Connect Certified.
Hifiman Serenade - Himalaya Pro R2R DAC headamp all-in-one
- Thread starter godmax
It's everything in my head but I must find some time to put them down on paper!@Ichos How is the review coming along?
I have to finish a couple of other articles that have priority and then it's time for the serenade.
Hint - the DAC section is really good.
MichaelVK
I've tried it yesterday - no results on Mobile (last version app Tidal), but PC version app found out Goldenwave via Tidal Connect. Mconnect app on mobile doesn't find Goldenwave via UPnP also .still no feedback if Serenade is now TIdal Connect Certified.
In list of support devices on Tidal connect pages, no Hifiman...
Works fine with me.
Is it the same dac section as Hifiman EF600? What do you prefer this dac or the Denafrios Ares 2?It's everything in my head but I must find some time to put them down on paper!
Thanks!
I am not sure about the modules used.Is it the same dac section as Hifiman EF600? What do you prefer this dac or the Denafrios Ares 2?
Thanks!
Sonically I believe that is more technical sounding from the Ares 2 (not tested 12th). It reminds me a lot of the Gustard DAC R26.
equalspeace
Headphone Modder (Link)
- Aug 12, 2016
This thing is a beast in DAC only mode to the Vioelectric V222. Incredible sound quality.
Listening w the HD 650. What the DAC is doing to present the soundstage is really excellent.
Yea i think the highlight of the serenade is definitely its dac sectionThis thing is a beast in DAC only mode to the Vioelectric V222. Incredible sound quality.
equalspeace
- Aug 12, 2016
Yea this piece is a keeper. The amount of information I'm hearing in the bass regions is so great. Mids are extremely detailed and weighty as well.
equalspeace
- Aug 12, 2016
Listening from the amp section of the Serenade from the 4.4 mm output with HD 650 now.
The sound is very competent. Basically the same character as with V222 but less dynamic and the wow factor is not the same. It's pretty good. Like you could live with the Serenade if that's all you had, but DAC mode from the XLRs to a balanced amp is definitely the way to go with Serenade.
Oh okay... switched to the XLR on the front of Serenade and I'm now getting slightly better dynamics and detail from the mids.. oof this is quite good. Soundstage is better from XLR output as well, more depth/width and better layering of the instruments like this. 4.4mm soundstage sounded kind of flat (less 3D) w less separation of instruments.
I just love the character of this DAC. The bass and mids are really lovely. Treble isn't lacking. It's not a stand out frequency from this DAC. It's there but not doing anything weird at all, very, very smooth. Maybe it's pulled back a hair from the mids and bass. Overall character of this piece is slightly warm, neutral.
equalspeace
- Aug 12, 2016
There's also some very low noise to be heard with the volume all the way turned down from either the 4.4 mm and XLR output. I hear it more audibly with the HD490 and much lower on the 650, but I can still hear it. I think this device sounds good enough from the XLR and so excellent in DAC only mode that I do not care if it's not perfect lol
Assationater
classic hifiman QC smhThere's also some very low noise to be heard with the volume all the way turned down from either the 4.4 mm and XLR output. I hear it more audibly with the HD490 and much lower on the 650, but I can still hear it. I think this device sounds good enough from the XLR and so excellent in DAC only mode that I do not care if it's not perfect lol
equalspeace
- Aug 12, 2016
It really is. Hifiman is passionate about sound, but def not about perfection. Some of the stuff they make is so good that you luv them even though there are quirks. This Serenade like the HE500 is going to be one of them for me lol
Definitely the best sounding dac amp i know to date that doesnt break the bank too much. It is just the QC man. I have to replace serenade to get the QC right. Mine was heavily imbalance to the right chanel. Tried some demo they also have the issue. Until just now i got my replacement and everything is perfect. Damn Hifiman QC.It really is. Hifiman is passionate about sound, but def not about perfection. Some of the stuff they make is so good that you luv them even though there are quirks. This Serenade like the HE500 is going to be one of them for me lol
