It is, but results are not so good. The bass becomes loose and boombastic
Yeah, but 6 dB @ 110 Hz is pretty extreme. I use 2 dB @ 40, Q of 2, and get really good results with parametric eq.
Thinking about the 400i's now - how well does it handle non-edm/pop music? Say OSTs or orchestral? Or even pop music thats not overly synthesized and have good vocals (something like Adele)? Would you tame the bass by a couple dbs to get more of a 560 sound?
How well do the 400i's take to EQing? Is it possible to approach 400 bass with something like +6db < 110hz?
Another reason im looking to upgrade is that this generation are much more comfortable and lighter
I hear the bass quantity on the 560s are even less than the 400i's and ppl compare the 560s against the HD800s all the time
They take it really well. A simple 5db boost in the lower region and they pretty much equal the HE-400 bass. HE-400 may still have the slight edge on extension, but it's so close it's negligible.
I keep the EQ off though, I'm really starting to appreciate other aspects of the sound. The mids and treble on this can are delicious, coming from an HE-400. The HE-400 handsomely failed in this region. Female vocals are fleshed out, and sibilants are non-existent. Really glad with my decision
Big? No. Noticeable? To me, yes. I believe that all units are now shipping with Focus A pads with the Focus pads an optional purchase.
Focus-A are now symmetrical and about the same in terms of polish.
yes e12 adds a little bass. Not much..quick question ... right now im using he-400i with fiio x5 ... on low gain im listening the volume most of the time at 90/120 ... i would like to know if adding an amp will change the sound signature cause i read sometimes that a better amp will improve bass extension and overall sound quality ... i dont have requirements just in term of overall volume
Edit : lets be practical , im thinking of fiio e12 or o2amp
Difference compared to the Focus pads? If so, their impact on the 400i's sound isn't as well documented as with the 560. However, the 400i has a little hump around 4khz much like the 560, and it's probably safe to assume that if the Focus-A mitigate that resonance on the 560 by dropping the 4khz region down by around 3db, then it probably does the same with 400i.
headphones will have this effect generally because they can't have a perfectly flat response but Its something that you will probably adjust to. . Also, these headphones are very revealing to most normal headphones and what you're hearing now is probably the songs sounding closer to what it was intended to sound like.Just received it.. Really amazing ..
Playing various genre with fiio x5 and woo factor happen quite soon ...
Just notice something with pop song mostly.. snare are a bit proheminent and take my attention over vocals .. just think its a bit too much
Dont know if i need to blame the headphone or my mind but i ll see ... or maybe the amp is not powerfull enought so the emphase is even more on high mids. ..
Overall its really revealing and i if the mastering is not good you can definitly tell . some easy listening pop are really flat and not defined and i guess they are to blame . some other as too much u shaped i was surprise how different some good materials sound compared to others
