I usually nevery listen to EDM.. But now I've heard the new Linkin Park album and I do agree the HE-400 excels with EDM. Although it does a lot of genres a lot of justice!
Just Wait until ur ears get the he500 jergulor treatment
Haven't tried the settings yet, but let me be the first to say THANKS!!!
Okay, got it all working...sounds fantastic
Brings up one more question though LOL.
So I now have a bunch of volume controls for this wonderful setup...and despite reading lots of threads on which way to set them all, I am getting conflicting information. Now to be honest and as I mentioned, I am new to all of this, so my listening skills may not be on par with everyone else's. I could be hurting the sound and not realize it.
Without further ado, here is the setup:
Laptop sound card to USB to Schitt Modi to Schiit Magni to HE-400s
I now have volume controls at the sound card/Windows level; Media Monkey (WASAPI); plus the EQ now; then at the Amp. What settings should I have maxed and where should I be adjusting levels?
It was suggested that I even though my .flac files are 16 bit 44100, I should set the DAC for 24 bit 44100 which would allow the windows volume to be set to 25% without losing any information. Next, I am assuming the EQ should be left at 0.0db and Media Monkey should be set to 100% with the listening volume levels set by the amp. Does this all sound correct? Seems to work even though it has been suggested windows should be set to 100% as well, but then even the lowest setting is too loud. But should I have windows at 100% and cut it at the EQ now?
Sorry if this is the wrong thread to discuss this or if I should start a new one, please let me know.
Thanks in advance for all your help.
Darren
If u use the laptop as a dedicated source for ur rig its said best to put volume on ur pc on max (as its digital) and regulate the volume through ur amp...
Doesnt the dac regulate itself to the bits (16/24) automatically?
For the eq thingie: one of the others can reply that better..
about the volume..if the volume is to loud (thats also because of the peaky treble that the he400 sounds unbearable loud very fast) try to go down with the volume on pc until u can use the volume on the amp a bit normally..but still..the shiit u use is not a very powerful amp..i find it odd that it is not usable with pc volume on max.. But i am guessing the he400 is very efficient to be driven then..Yep, laptop being fed by a 2 tb media drive.
Re: the DAC...it was posted elsewhere on the forum to specifically go into the DAC properties and set to 24/44,100 even though the files were at 16/44,100 which allowed lowering of the master windows volume without discarding any information as the other 8 bits were empty. Sorry I can't elaborate, but I don't yet understand all the science.
If I turn my master volume to full, even the lowest volume on the amp is too loud. The new EQ settings helped with this a bit, but not enough to put the system volume to 100%, so I have to attenuate somewhere prior to the amp.
Darren
If you don't like using the windows volume control you could use WASAPI plugin which bypasses the windows volume control. Then you control the volume using the slider in Foobar.
http://www.foobar2000.org/components/view/foo_out_wasapi
Hi,
Am using WASAPI on exclusive but still doesn't bypass windows audio control...at least not on my system. Additionally I do not have a problem using windows audio control, just looking to make sure I am not hampering sound quality by doing so.
I will try to find the thread on this and post it.
Darren
Nah I doubt it.... Just set the volume to 30% or something... I do not think it is really an issue with windows 7 / 8 ....
