When I lose 1 side of the headphones it continues on to any device for the next x minutes, about 5. I have to let it "rest", unplugged for it to come back. Seems like any sort of power won't let the side come back on.
OK -
I have tried switching the wires around, no help in the long term. I got the wire from Ted Allen from HeadphoneLounge, if that matters.
A non-stock wire? Do you have the original wire that came with it? IF so, I would install it and see if both channels work. It is at least possible that the custom wire has an issue.
The cable connections on one side
do not ever secure. I'm not sure why, but it's been the case for a while now (Before this issue presented itself). I can keep spinning it forever and ever. It will stay on for a while before falling off again, Other side is fine.
Which side is broken? Is it the L Channel which is giving you the issue? I believe there is glue holding the SMC connector in place. If it has let go, that would help explain why you can never actually tighten the wire properly. IF you cannot tighten the connector properly, that could be a good reason the channel cuts out on you. You might be able to hold the SMC connector in place with pliers if you remove the grill ring / grill and reach in there carefully, then hand tighten. Worth a shot, perhaps.
Maybe it is the wire, I haven't been able to test it 100% one way or the other. Right now the issue has stopped happening since I made that post (And I don't want to meddle with it while its going good), but i'm 100% sure it's going to come back sooner or later.
Only thing I changed is switching the wires since that post, though I've done that before and it has never consistently fixed it all the other tens of times I attempted it.
> so that the R Channel is plugged into the L Channel. Does the issue move to the other side of the headphones?
I didn't realize that one side is specific to left and to right? Mine are just colored blue/red so I'm not sure which is which. Custom wire after all.
You have confused my instructions. What I meant was, simply disconnect the wire plugged into the R cup, and connect it to the L cup. THEN, connect the wire that was plugged in to the L Cup into the R cup. Stock wires for the HE-400 indeed have an L channel and an R channel. What you're doing is seeing if the problem is following the wire connected to the L or R cup. IF, when connected to the L channel, it does not work, but when connected to the R channel, it does work, that would rule out that you have a faulty wire.
> What color is your driver casing? There were certain older versions of these headphones that were prone to losing a channel, I thought.
I'm pretty sure I got mine after that was fixed, mine are white last I remember. I dont feel like opening the grill again, it's a pain getting it back on. Here it is: http://i.imgur.com/j0VXlEm.jpg
OK
I'll contact him thanks
It sounds as though you have a damaged pair of headphones, with the 'infinitely turning" SMC connector you describe. It can probably be re-secured and re-glued assuming the connections to it are not broken or breaking. First, I would try other wires, or run the test as I described on your custom wires. Failing that, I would remove the stock outer grill to see if you can hold the SMC connector and properly tighten the wire to it. When my wire gets just a little loose, it can give random-feeling cut outs. What is more, the plastic jacket, before it tore, would apply enough counter-twist to back the connection out over time. Caused me a lot of anxiety at one time.
