Nick, looks like you are going to have to learn chinese
Hiby R6 Pro II (2023 Edition) - Launch, Hype, Thoughts & More
- Thread starter Zaghamkarim
Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
The program in HiByMusic to obtain lyrics cannot yet be modified as such.Hi @Joe Bloggs thank you for your reply
Okay, it is clear to me now re: Default Settings = Optimal Settings and about the HiBy account.
Regarding the Lyrics, I do not have them saved in the metadata of my audio files. I thought HiBy Music App would fetch them from the Internet but it does not work. It brings lyrics for other songs. Some of them are with Chinese characters. Is there a way to set the website from where it will get the lyrics?
For example, this one:
https://www.musixmatch.com/
Note: I would like to clarify that I am referring to the setting: "Obtain lyrics and cover art online"
I would suggest to obtain the LRC files first using this: https://github.com/fashni/MxLRC
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
Put in a couple of DSD albums just out of curiosity to see what difference there is and the only way they play well in the DSD setting is in PCM mode, in DoP the sound is garbage, so do DSD files have to be played in PCM mode ?
One thing I've observed: the battery charging limit is kept (remembered) only if the device will never power off.
If the device is shut down, either by the user or if the battery will deplete, it charges up to 100%, independently from the set charging limit.
I had it playing until the battery dropped down to 0% and it auto shut down. Then I plugged it into the charger and, as soon as it reached a certain level, I powered it on again. It kept charging past my set limit, which is 85%
@Joe Bloggs is there an ETA for the new firmware which will, eventually, fix the already reported Digital Filters' issue, together with the other one re: HiBy Music I've reported, and can we hope for a bigger icon for the battery charging progress [bar] while the device is powered off?
EDIT:
Sorry, do I need to do something specific to set the battery charging level to 85% , for example? Because it does not seem to work for me!
Since yesterday, I've set it to 85% by going to Battery / Max battery and pulled back the slider to 85. Then I shut it down.
Today, when the DAP was at 13% and without shutting it down, I've plugged it into the charger and left it.
When I returned back it was at 89% already and I had to unplug it to stop it!
EDIT:
Simon Patten
Is it still set to 85% but charging to 100%?
Edward Ng
@Nick24JJ This will happen if the DAP is powered down while charging. The 85% cap is software-based, and when the DAP is powered down, the software is not running, so it goes to full. You must leave it on while charging to prevent going past the cap.Is it still set to 85% but charging to 100%?
-Ed
Like ED said if it is powered down it will keep charging, be good if there was a way it was not software based. My Samsung phone even when powered down will only charge to the 85% that is specified by myself.
-Ed
Yes, this is what I did, left it on and started to charge it when it was at 13%
The limiter was set to 85
I will test further
Thank you
HenjieT
- Nov 19, 2014
I play my DSD files natively with no issues. Using UAPP though.Put in a couple of DSD albums just out of curiosity to see what difference there is and the only way they play well in the DSD setting is in PCM mode, in DoP the sound is garbage, so do DSD files have to be played in PCM mode ?
I play DSD native with Hiby app and UAPP. No problem.I play my DSD files natively with no issues. Using UAPP though.
I see, so in the Hiby's DSD settings you are in the Native setting ? On mine it sounds fine on the PCM setting however sounds terrible on the two other settings. It sounds as if it has no EQ whatsoever, tried turning the EQ, and other settings off but no difference. By the way these DSD are files that are on the Hiby itself not streaming.I play DSD native with Hiby app and UAPP. No problem.
Yes native option on the hiby app, not streaming too.I see, so in the Hiby's DSD settings you are in the Native setting ? On mine it sounds fine on the PCM setting however sounds terrible on the two other settings. It sounds as if it has no EQ whatsoever, tried turning the EQ, and other settings off but no difference. By the way these DSD are files that are on the Hiby itself not streaming.
I must be doing something wrong, cannot understand it as it is pretty straightforward.
There might be a setting I need changing that I have not touched, shall look ltr on thx for the help.
I do not understand why the Max Battery setting does not seem to work on my device.
Here is what happened this morning:
The DAP was left with 0% battery from last night.
This morning, I plugged it into the charger. After reaching around 20% I powered it ON. After a little while, when it had reached 30%, I unplugged it, I restarted the device and I plugged it back into the charger.
I've left it charging and right now it is at 87%, while Max Battery setting was set to 85% all the this time, since yesterday!
All I am doing is setting the Max Battery slider to 85.
Why does it not work? Why does it not remember the setting?
Is there something else I should do to set this limit?
I understand that the Max Batter level is not respected when the device is powered OFF and left charging.
It seems, though, that this setting is not kept/remembered/respected, even when you start charging and power ON at some point before reaching the limit.
It also seems that it is not respected even when you unplug and reboot.
@Joe Bloggs ?
@Joe Bloggs ?
HenjieT
- Nov 19, 2014
I also have mine set to 85% max but I've experienced it charging to 87% once, and 86% twice. It's just those three instances though.I do not understand why the Max Battery setting does not seem to work on my device.
@Joe Bloggs ?
I always charge mine when it gets to 25-26%.
