Hiby R3 Pro Portable Bluetooth DAP
May 16, 2023 at 10:41 AM Post #2,004 of 2,094
Qobuz does not work anymore. Every try I choose any track from any list I got "HTTP error code:400 Bad request". Navigation through lists and search are work though. It also works from Android client and PC.
May 16, 2023 at 11:42 AM Post #2,005 of 2,094
When I had Qobuz, the R3 Pro worked great for steaming music.
- But it could not save, or play any saved Qobuz saved music files. HiBy said that it was not possible to play downloaded Qobuz files because the R3's are Linux Operating System. If Android, would have been easy. Could also be some licensing involved too...
- Think that Tidal has the same "streaming only" limitation.
May 16, 2023 at 1:44 PM Post #2,008 of 2,094
I'm trying to find out what the issue I have. Tidal works fine right now, but Qobuz client is denied to play any track on R3Pro 2022 fw2.2.
Interesting... I've logged out Qobuz, removed files /data/qobuz_* rebooted and then Tidal stopped work too.
The log is crazy
curl_easy_perform() failed: Error
(hgl_fb: I) hgl_hw_fb_suspend fb_ready=1,fb_suspend=0
(GUI:D)lg_timer: timer set or kill by self.
(GUI:D)lg_gui_message_instance: hgl_scene_render begin
(hgl_fb: I) hgl_hw_fb_resume fb_ready=1,fb_suspend=1
(GUI:D)lg_gui_message_instance: hgl_scene_render end
(GUI:D)lg_activity: create hglview=vg_dialog_online_module
lg_begin_thread status:0
(GUI:D)lg_activity: LINE= 1304,remove hglview=vg_dialog_online_module
(GUI:I)lg_listview_create: 2168 : lg_listview_create : enter
(GUI:D)lg_activity: LINE= 1304,remove hglview=vg_where_songs_hiby
(GUI:E)get_str_res.c: error!!! not find string '',line: 204!
(GUI:D)lg_activity: create hglview=vg_listview_main_explorer
(GUI:I)lg_listview_create: 2642 : lg_listview_destroy : enter
(GUI:D)lg_activity: LINE= 1304,remove hglview=vg_listview_main_explorer
(GUI:E)lg_listview_create: list init err!
(GUI:D)lg_activity: create hglview=vg_where_songs_hiby
(GUI:D)lg_activity: LINE= 1304,remove hglview=vg_category_label_hiby
(GUI:D)lg_activity: create hglview=vg_songlist_label_hiby
(GUI:D)lg_activity: create hglview=vg_exception_hiby
(GUI:D)lg_activity: LINE= 1304,remove hglview=vg_songlist_label_hiby
(GUI:D)lg_activity: create hglview=vg_category_label_hiby
(GUI:D)lg_activity: LINE= 1304,remove hglview=vg_exception_hiby
I removed /data/usrlocal_media.db , rebooted and re-logged in Qobuz normally. But that HTTP 400 error on any track is popped out again.
Even reset to factory settings didn't help.
