Yanec
- Sep 19, 2013
Thanks! You have a very good point there.The resistor matching level is not particularly extraordinary. What makes it all work is our linearity compensation technology. To grossly oversimplify, it takes the input values of the digital data assuming an evenly spaced grid of 2^bd values (bd=bit depth) and maps it correctly to the actual values of a non-evenly spaced grid produced by an imperfect R2R network, ensuring output linearity whatever resistors we use (within reason). This was sort of glossed over, briefly mentioned in the ad copies, but should really be a big selling point...
Both Amir from ASR and Paul from PS Audio have told me at certain times that r2r would be their preferred dac if the need for high resistor tolerance can be addressed properly. Paul even made a video on this several years ago.
It seems you have discovered one way to address that, you should definitely use it more as marketing.
Is the compensation two part: hardware plus algorithm(software)? Is the algorithm part resampling or altering the signal?
