Wmcmanus
President treasurer secretary and sole member of the Cayman Islands Head-Fi Club.
- Nov 29, 2002
Man oh man, I had hoped this day would never come, but maybe someone can help me out! I just got back to Cayman the other day for a brief pit stop (will be leaving here on Thursday morning again), and decided to give the Orpheus a quick listen.
While I was gone, I had unplugged my entire headphone rig from the wall (several sources and amps are run through a power conditioner which is then plugged into the wall). So I plugged that back in and turned on the key to the HEV90. No power! Huh?
Then I realized that I hadn't turned on the individual switches on the Tice Power Block. So I turned the HEV90 key back off, then turned all of the Tice switches on, and powered the HEV90 back up by turning the key to the on position.
The result was kind of shocking: the left output jack is just getting a left signal, while the right output jack is just getting the right signal. It doesn't matter which headphones are connected to each. I've powered down and back up several times, swithing the HE90, Omega II and 4070 from one side to the other. Left jack gives left signal, right jack gives right. It's really as you would expect it to be if the HEV90 was a BALANCED amp, which of course it isn't! I should be able to listen to 2 pairs of headphones (each receiving left and right signals) simultaneously.
I've had the HEV90 for 3-4 years now and have never had a problem with it. I'm wondering if something went haywire due to the fact that I turned the key on and back off without any power going to it. I guess the other thing is that I initially had my Stax converter cable plugged into the left output jack, but without any headphones connected to it. But it seems to me that I've done that before and have never had any trouble with the amp, so I wouldn't think that would be the problem.
This kind of thing kind of scares me: living in Cayman where I'd have to ship it back and forth to Germany to have absolute assurance that it would be fixed by people who know the design intimately. Or alternatively, having someone in the US take a look at it, which I'd be hesitant to do because it's a pretty complicated design and everything inside is an extremely tight fit.
Any ideas about what may have caused this to happen and what I might be able to do to get it working properly again?
