money4me247
- Jan 27, 2013
markm1, that is some really good advice!! I totally agree with what you said. less is often more & I find a one track audition to generally be enough to guage how the headphones will be for my tastes. the most important thing is to be intimately familiar the few tracks that you use to demo so you can quickly spot differences. try to demo with too many different tracks at once gets quite difficult as our brians focus on different aspects with every listen. I personally like to test using the same track multiple times focusing on one specific thing at a time (first time just overall balance/sig/what stands out/any glaring flaws). Then I focus in on portions of the track that stood out to me, relistening to ~30 second clips checking the bass, mids, and treble only with each relisten of that specific portion of the track. then overview again just too see what parts the sound sig naturally focuses on. you can often hear tiny things per frequency response region if you are focusing on it, but then relisten to that part and see that detail isnt really present when listening to the whole). I do believe you can get a lot of information from a critical one song comparision. Another recommendation I have is to bring another pair of headphones with you as an objective reference point that you can compare everything back to and build a frame of how everything is different specifically against that point. I do this when I think there is a glaring difference, I relisten to that short segment with my reference pair and the new pair. sometimes things you think are different turn out to basically the same if you do that comparision back as our brains can perceive a lot of differences just by subtly changing the audio focus (even when listening to the same track with the same headphones). i'm sure everyone has had that experience of hearing a brand new detail on a track you have heard hundreds of times.
anyways, great advice man. keep it up.
