Heya,
Well, this is a HE-500 we're talking about, not a HE-6. I don't think the HE-500 would tolerate having that much power blasted into it. I think it may be pushing it just doing this even. I'm just curious to see what it will do on a speaker amp with a ton of power, compared to headphone amps. The HE-500 is relatively efficient for what it is, but I'm curious to see if it can benefit from a higher current basically. It just so happens that you can get more power for a planar magnetic from a speaker amp than a headphone amp, and at a lower price to boot. $220 for a good speaker amp that outputs 10 watts roughly into the HE-500 is quite different than the $450 Lyr or other amps that don't even output as much. The difference I'm looking to see is if there's a noise floor difference, or any kind of detriment using a speaker amp, compared to a headphone amp meant for such a headphone. I think it's well established that the HE-6 is great with a speaker amp. But the HE-500 is efficient enough that most folk looking at it are not also looking at speaker amps. So it got me curious to see if it makes a difference with it too, because really, if the HE-500 and a speaker amp do very well together, it makes for a relatively inexpensive way to enjoy a flagship level planar magnetic since the HE-500's cost dropped (and it's used cost is straight crazy, it's so good now), and the cost of a good speaker amp is half what a good headphone amp capable of pushing the HE-500 to it's limits costs.
It's new territory for me since I've got no experience with speaker amps connected to headphones. But it does open some fun doors. And if not, well, the Emotiva will not go to waste since I have several speaker setups that it can definitely be integrated into and be useful.
The cable I have commissioned is a 6 foot brained sheathed cable that will work with any Hifiman HE series headphone, that terminates to XLR. Then two adapters are made for it, both are female XLR. One terminates to 3.5mm and a 1/4th adapter for normal headphone amp use. The other terminates to speaker taps (banana plugs). So it will be a universally useful cable. And if all of this turns out as a bust, the cable itself is still a great cable that can be used by someone else with a HE-6, so I can sell it if it really doesn't satisfy my curiosity, and of course, the cable itself is still very useful since it's universal and I will likely keep it (but the adapter could be handed off if it doesn't work well).
Very best,
