2bxfile
Hello:
I'm looking to buy a Mimby and at the same time was looking at the Singxer F-1 or SU-1 (which is a stand alone DDC) to accompany it. I will be having a laptop starting off my chain with USB to F-1 or SU-1 to Mimby to integrated. Below is a piece of "project86's" (a poster here at Head-Fi) review of the Singxer SU-1.
What I wanted to ask you all, is after reading the below, would a Schiit Multibit DAC be a good candidate for this DDC piece of kit? Would it marry well given the below points?
So far, so good right? The Singxer SU-1 is a killer value with superb sound quality. Should everyone rush to place their order? Not quite. As with all other DDCs, it really depends on your DAC. The main problem as I see it is with the SPDIF implementation. All the fancy digital to digital conversion in the world won't do you much good when passed through a CS8416 DIR with its high intrinsic jitter. Which means some DACs just aren't good candidates for this type of improvement. Also, some DACs (the Anedio D2 for example) essentially have an internal DDC where all signals end up taking the same path, while others pass USB data directly to the DAC. Meaning potentially a shorter and more pure signal path compared to even the finest DDC. Do you know what your DAC does and what that translates to in terms of upgrade potential with a DDC? If not, you might want to find out before making a purchase. Granted a $399 device like the SU-1 is a smaller risk than a nearly $2K Alpha USB, but it's still good to be well informed before spending any amount of money.
Thanks so much fellas for any help you can offer
