TheGame21x
I'm surprised it would show up without power. Source lights on the front dark?
Yep. I'm hoping it's just the wallwart but I won't be able to tell for sure until I get a replacement in.
The USB sections are powered by USB, even the Yggi is this way. The DAC is what's powered by AC line power. At least that's my understanding.
I think the most recent versions of the modi uber are self powered (don't show up when the DAC is not powered). Not sure about the Modi MB.
This is kind of weird for a few reasons. I've never heard the emotiva pieces, but am very familiar with the others, and the hd650s and bottlehead are among the least likely components to come across as too forward or sharp (fatiguing, maybe? Just trying to understand what you are hearing.) Both are commonly thought of as pretty smooth and laid back, especially the hd650. It is possible that the speakers will get better with time, but that kind of change is usually pretty subtle/incremental, whereas it sounds like you are wishing for a more substantial change. The modi multibit is a pretty noticeable and substantial change from the 4396 uber, especially for different versions of the same model, but differences between dacs are always pretty subtle. Definitely much better to my ears though. Just don't know if it will fix what you are unhappy with though. When you say you are using "2 y adapters" to connect the modi to your amps, what does this mean? It should not take adapters of any kind to connect them, just an rca cable from the analog outs of the modi to the input of whatever amp you are using. Maybe you just are using different terms? Also curious as to what the speakers, Fusion, and Modi replaced, thinking maybe just a very different sound signature requiring a big adjustment? Aside from all of that though, I absolutely love my Mimby, best $250 I have ever spent.
> Can an audio setup sound fatiguing very soon after a listening session, or is fatigue in an audio sense usually related to longer listening sessions?
If you feel like you're being beat up listening to anything it's fatigue. I felt this way with my Beyer T90s. The wow factor of clarity (which was substantial, I won't lie) was eventually replaced with a feeling of distaste for the virtual beating I received listening to just about anything. I've found that bluegrass music is particularly good for determining if you're going to feel fatigue. If you cue up some and immediately find it grating then something is wrong with your chain. Even if bluegrass isn't to your taste you shouldn't find the sound harsh/grating. What was intolerable on Beyer T90 is joyful on Senns HD600.
I had the HD600 before the T90 and it is indeed a special HP. But it did not resolve complex classical orchestral music the way I wanted (smeared complex sections), and the T90 fixed this, and I mostly listen to classical so obviously it was a priority. I sold the 600 but may buy them back and use them for vocal stuff.
That's funny, I recently got the HD600 and it's the best headphone I've ever heard, and I really do like them, so maybe I should just stop here so I don't know what I'm missing?
Ignorance is truly bliss... ah but know about it! I'll have to try some memory repression...
Ignorance is truly bliss... ah but now I know about it! I'll have to try some memory repression...
Don't worry, like everything else, it's all tradeoffs. Fast transducers also sometimes drive people mad over the characteristics of minor details of the sound, especially the decay.
