Quadman
- Nov 26, 2015
@Quadman
Thanks so much for that information. I'm a little releived to hear that.
I will currently be using the balanced outputs with the JBL LSR305s, do you think the 6.6v output voltage cause any problems? Also, does it output higher voltages on the RCA outputs as well? Because I am planning to add a headphone amp on the RCAs at some point and dont want to fry the amp/loud pops on the headphones lol ..
And since you mention it outputs higher voltage, I'm assuming you need to keep the volume lower than at full volume right? So, at what point in the 100 step volume does the X20 actually starts affecting the bitstream?
And, although this does not add any value to this thread, but I'll ask it anyway, any thoughts about the NFB-28, which is the one I'm considering as well. Any comments on the Audio-gd's descrete/complex looking designs with 1x9018 vs Gustard's surface mount board + 2x9018 design. (Leaving aside the obvious difference that the NFB-28 comes with a headphone amp)
Ric measured 3.3 V on the RCA outs so make sure the headphone amp has the "headroom". I believe each 6 dB change in volume half's or doubles the voltage (depending which way you go), so -6 dB would be 1.65V on RCA and 3.3V on Balanced, -12 would be half those numbers again. I generally play my gustard in the -11 to 0 range and I can tell no difference in SQ between those numbers. Not really sure when an audible effect would occur but it would probably be lower than -20 dB. As far as SQ this dac is way above its price point.
I know nothing of the NFB-28 but one the first thread here Marty does a mini review of 4 Dacs. http://www.whatsbestforum.com/showthread.php?20090-DACs-Galore-and-Expectation-Bias
I'd say the Gustard Holds its own.
@Wynnytsky I use dexoit as my cleaner/contact enhancer have been pleased with it. Ric keeps talking about Quantum Chips and the improvement they make on this Dac, I still am unable to pull the trigger on buying some, maybe to much voodoo.
