Just out of interest for those in the UK.
I didn't really think about the voltage of my X20 much once I'd got it, beyond checking it was set
correctly when it arrived in the post. However, when I recently modified the power supply section, I
took out not only the IEC connector, but also the voltage selector.
Now, whilst the manual states that the input voltage is an EU harmonised 230 volts. The actual physical
selector on the back of the DAC clearly states 220 volt (on my unit anyway).
Why this is of interest to me is that if the DAC is actually manufactured to 220 volt standards, then it
might only be rated up to a maximum of 242 volts, as per standard supply specs.
Of course, extra tolerance has more than likely been built in, and there's probably no reason for concern.
However, when I was working on the PSU section, I measured the voltage of my incoming supply at around
249/250 volts ( not that uncommon here in the UK ).
Having always been a touch concerned that the two capacitors supplying the digital section of the board
always seemed pretty hot to the touch, whereas those on the supposedly more demanding output side always
remained totally cool. I decided to have a play around.
In my system the X20 is powered by a EquiTech balanced transformer, with input and output voltages both
handily displayed on it's built-in screen.
So, I wired up a 'buck' transformer in front of the EquiTech and ended up lowering the overall input voltage
to 216 volts ( not perfect, but well within the 220 volt spec ). The X20's two transformers now measured
much more consistent output levels than previously, at 8.9 and 14.9 volts respectively. ( should be 9 & 15 ).
And after a few hours of playback, the two digital supply capacitors were running much cooler than previously.
Is any of this relevant ?
Well ... The fact that originally the X20 was sold with a stated output by vendors of 2.3v rca and 4.6v xlr,
and 'still' is on many sites. Which totally contradicts the official Gustard manual which gives output stats
of 2.8v rca and 5.6 xlr. Whilst the actual measured output of an X20 has been shown to be 3.3v rca and 6.6v xlr.
Doesn't exactly inspire me to have confidence in any of the DAC's stated tech specs. And, the fact that the X20
now seems to be discernibly smoother sounding with an improved noise floor, at the lowered input voltage, does
have me wondering ...
Despite being a good value product, the X20 is not a cheap item. I understand that Gustard design the DAC and
then have an electronics sub-contractor manufacture it. But, I simply don't see this sub-contractor building in
a switch that has 220v printed on it, if it were not specified. They would quickly go out of business if they
couldn't get something as simple as this correct.
Don't get me wrong. I really like the X20, I thinks it's a very good buy for the money. The power supply
modifications I've done recently have brought out a particularly deep rich smooth character to the sound.
However, on a pretty Hi-Tech item like this I don't think I should have to be wondering about what it's
input voltage really is, or what its output ratings really are. These should be clearly stated and correct
from the very beginning, and there's no excuse for them not to be, as this is really basic stuff.
Of course, the voltage side of things only really effects UK based customers, as we are on a 240 volt
supply. Those in europe should be fine with their 220 volt supplies.
Anyway, sorry for the rant, but stuff like this does rather annoy me. Lol ..
Lets not get started on the fact that Lucian, who produces the WaveIO USB/I2S card manages to supply
a full registered custom version of the latest Xmos Thesycon drivers. As well as first class customer
service. Whereas, it looks like Gustard (a vastly larger concern) are happy to leave their X20 customers
only able to use an old pirated? version of the Thesycon drivers. Which is why they state that the USB
input only goes up to DSD 128, whereas with the proper drivers it goes to DSD 256 no problem at all.
Leaving X20 users having to get something like the Tanley or WaveIO etc, if they want the better drivers
and sound quality.
Anyway, I'll run the X20 at 216 volts for a while, then swap back to my normal 240+ish in a few days to
see if I notice a difference in sound quality when I do so, and will report back then.
Cheers.
Simon
