- Oct 26, 2008
Ya'll got me intrigued with this. Looks so simple and clean. Any comparisons to other common USB converters?
+1. I notice a smoothness or greater musical flow across the board. Better defined bass as well.. Are you running the ASIO driver?Got my Gustard U12 today, and it sounds excellent. Much better device than the Peachtree X1. The X1 by itself sounded pretty harsh with distorted highs and was unlistenable to me without a Wyrd. Clearly the USB +5V noise was beyond it and affected its PLL badly. Swapping out the X1 for the U12 helped smooth out and clean up the sound substantially, and although I can tell on any recording it's most noticeable on really bad ones (think Amy Winehouse / Back in Black). When I have time I'm going to try it with only the U12 and no Wyrd. But between the X1 and U12 there's no question which is better spent money...
I've had the M2Tech EVO fed with a custom linear ps, an Audiophilleo2 and a Musiland USB 3.0 fed by a Aqvox linear ps. It's better then all of those in my system.Ya'll got me intrigued with this. Looks so simple and clean. Any comparisons to other common USB converters?
I use the excellent Stilnote USB, after trying 4-5 different USB cables. Not going AES.Has anyone tried the AES/EBU balanced output from the U12? Thinking of getting a cable just to try it out...
Yes, and with Jplay! I never did get the battery supply. I really liked the M2Tech EVO which I did try with a Lipo battery ps, but preferred the Apocain Yellow Box linear ps I built. But the Musiland surpassed both of those. The Gustard is at a whole new level.Better than an Audiophileo? That's a pretty strong statement. Thanks for the info.
Mine arrived today and the smile cannot be wiped from my face. I always had my skepticism about reclockers but 0.1PPM made me sit up and take notice.
No bloom, No glare, smooth passage into the ear canal without any harsh ringing.
My recommendation is to buy it now before the price sky rockets and buy shares in Gustard!
No difference with or without the Wyrd that I can tell... makes it an even better buy!
