For me the 2G has been worth every penny times 10. But for those on a budget I would recommend the Forza Twin Copper split cable, then the Supra. I've had USB cables costing over $500 - the 2G smokes them. But I do have my limits, won't spend $1000 for a 10g.
That will be interesting on the clocks - can you switch them on the fly?
I have not used a hot air soldering gun. Which one did you get?
Not exactly how I have it planned... I mean... Not on the fly. Although.:.. I could do that if I get the right parts
I need to figure out how to mount a dip14 sockets on this tiny board. It's like putting a square in a round hole. It's just not supposed to happen.
But it's possible I suppose. Likely wouldn't be ideal as the longer the connections to the crystal the more likely it would interfere with its performance. Just my thinking anyhow:
But to remove this xmos board, it's a bit of a chore that requires patience.
I ordered a Talema breeze du-u8 too... And likely will reorder that pro3a from the sounds of it you may like it more? But I really just want to hear it first.
Do you know anyone hat has swapped the crystals in a breeze? And has photos to show the underside of the pcb or how easy of access it is to remove the crystals and install dip14's?
Just at a glance it looks easier than even the u12z should be a breeze right!?! Sorry... I had to.
The breeze will get 957's for sure. But the diu8 I may try 575's at the very least. I'm torn to if I can get a 957 to fit.
I think the 575 should be 99.5% the same. So I'm not too worried. Actually... LKS confirms the 575 sounds better than the 957's in their USB Amanero implementation. So that makes me feel better.
Funny thing is, I'm likely going to sell all but one DDC in end. Maybe someone will get one of my Frankenstein builds. Actually, all my ddc's will likely be sold once I get the Lhlabs geek source with triple femto and all the other power upgrades. It is also xmos but will be insanely high spec! That being said, I doubt any of these ddc's will have a chance. This doesn't stop me from being curious and tinkering/DIY. And others can learn from my experiences too.
I'm talking with Dacladder about repairing my u12's coax. I want it to work if I decide to sell it.or find someone who doesn't need coax and only needs i2s HDMI. Will sell for a cheap price!
