MINORISUKE
- Jan 29, 2015
i had channel swap using the hydra i2s with an x12 dac, but i haven't opened up the hydra to play with the its i2s options yet.
I suppose the default I2S configuration of Hydra Z is "PS Audio", which means Pin No.1/3 and 7/9 are reversed compared with X12 (and U12, Tanly). 7/9 makes channel swap, 1/3 absolute phase polarity swap.
On the other hand, I am sure that U12 has a channel swap for DSD. The owners of both U12 and X12 say there is no channel swap for DSD by connecting both with an HDMI cable.
This means X12 has a DSD channel swap internally in case HDMI LVDS I2S/DSD input is used. Its USB input seems to have been fixed regarding this issue, but not for HDMI LVDS input.
If Gustard fixes this for HDMI LVDS input, then the faulty output of U12 will become obvious and they have to fix U12 as well.
I assume Gustard does not want to fix U12 and leave X12's HDMI LVDS faulty input intentionally unfixed. I am also afraid that the new DAC-X20 might have the same issue.
In case Hydra Z has no DSD channel swap (and it should be without such a problem), connecting Hydra Z to X12 will cause DSD channel swap due to X12. You have to change the internal dip switch of Hydra Z every time you change between PCM and DSD.....
Unless you experience channel swap for DSD with X12 (i.e., in your current Hydra Z configuration, PCM swapped, DSD also swapped), then Hydra Z has the same issue as U12.
