auvgeek
- Aug 8, 2014
Do you mean rotational or translational play? Mine has a couple mm of play in it translationally in every direction, but it doesn't affect the volume control at all.
Originally Posted by BassDigger /img/forum/go_quote.gif
He said his 'bread and butter' work was changing capacitors in equipment that people had left 'always on'; particularly the Arcam range of CD players that had their DACs permanently connected, bypassing the on/off switch.
Regarding class A operation: it uses maximum power at zero output; the bigger the output signal, the less the power requirements and the cooler it will run, strangely enough.
That shaft is held with ball bearings at the side of volume knob, and the ball bearing is being tightly pressed into drilled out cavity by heads of 2 screws. Tolerances there are all very tight on my H10, and there is no play at all (feels rock solid), which is probably why it starts to bind so easily with the slightest misalignment (maybe I should try to introduce some slop there!). I would say that this design of volume shaft requires a bit more precision in assembly than manufacturing facility was able to provide.
Overall I think we are in violent agreement,
Anyone encountered problems with USB? I tried all of my USB cables and different USB ports. Nothing.
99% of DACs require external [manufacturer's] drivers with Windows. The disc was included with your X12
