Yes, my 'issue' (its really more of a nitpick, not issue) is unrelated to music being played, more of the opposite - when it is NOT played, if I get my ear to speakers, I can hear high frequency 'whistling/beeping' noise carried from my computers (tested with 2 computers with same result). DACMini in same configuration results in MUCH quieter noise that is closer in character to white noise.
Also, I think the USB cables that I got are the newer, 'improved' version of the bundle, they have ferrite beads on them.
@HiFlight my Samsung S5 works fine with 9xx with either battery power applied to 'power' connection or not.
Now, usb audio on android was always a sore subject. There used to be no support of it, other than special music player that came with its own usb audio device driver plus horrendous playback interface (USB Audio Player Pro?) plus couple of OEMs that applied patches to standard android to make that work (Samsung is one of them).
I have heard that it is improving recently and support for standard sample rate 44.1 was added into android core, but can not attest to it, since my LG G2 still refused to work with external dac last time I tried (couple months ago).
Again, Samsung phones should support external dacs, but that support is still wonky. I find that connecting a200p to my S5 is infuriating experience - 4 out of 5 'connections' result in sound played very slowly (half speed?) with lots of crackling. And then I re-plug - and voila - it works fine. I thought that was a200p problem, but yesterday same thing happened with 9xx - something is definitely wonky with samsung's audio drivers.
Ah, and if anybody wonders, I use lowly VLC for playback on S5. Works as good as some other fancier apps that I tried, and has good directory browsing mode which is a must have for any listener of classical music (tags are always a mess, no matter how hard one tries).
