kanuka
- Dec 12, 2010
thanks. i may try once more. that's the 1st time i try trimming
so , no bi-flanges suggestion?
mmm they are the same of the m6. havent you tried them?
and today i tried MY trimmed to bi-flanges and summing up, noticiable worse isolation than the clone sony hybrids, though a slight more comfort and better fit, vut not worthy. i might keep them for the comming B2...
but if you did tried the m6 bi-flanges, how do you compare them with the sony hybrid (clones), in isolation , comfort , fit , etc?
My M6 is the older version and doesn't come with bi-flanges.
[EDIT] If the bi-flanges is the same one as A151, then I do have that one and it will fit PL50. I prefer Sony Hybrid on PL50 because it has an easier, more comfortable fit. the MEElec bi-flanges. But MEElec bi-flanges offer a little better isolation.
... There are so many selections at meelec, any recommendation?
thanks alot for this helpful thread
http://www.meelec.com/MEElectronics_Original_Eartips_for_M11_Earphones_p/tipset5-m11cl-mee.htm
will all those fit the turbines? It looks like a better deal, and I really want to try out their tri flange as well, are those basically like the factory tips from monster? or better
would these fit as well?
http://www.meelec.com/MEElectronics_Original_Eartips_for_M11_Earphones_p/tipset10-m11+cl-mee.htm
are you adding the ety's "mushrooms" ?
There are some unmenntioned small olives available from Sennheiser, included with IE series. Better than other olives for the deep fit for my ears - as long as they stay on the IEMs.
Material seems similar to small Shure's (slightly harder), but the nozzle end is wider, they're slightly shorter, far slimmer and end flat instead of tapered ball.
I can't find them available separately and don't know the part number for direct order. I'd like to have some spares just in case. Any help?
Edit: never mind, found the right thread: http://www.head-fi.org/forum/thread/408541/how-to-buy-senn-ie8-replacement-tips
However, a pic of those would be useful, they're quite different. Biflanges too are different, not tapered.
