Papander
- Mar 5, 2012
Getting headphones loud doesn't mean that they're powered properly. The need a lot of power and current to work well. You can get them loud out of an ipod, but they won't sound nearly as good as out of an amp. Loudness is not sound quality. Also, their impedance is 50 Ohms only on paper, its actually not constant, it has a big spike that goes up to 300Ohms. You can use them without an amp, but you'll be wasting your money. You better buy cheaper headphones then, you'll get the same sound out of them.
Isn't amps purpose to amplify the signal with minimum distortion to signal. The more I amplify the signal the louder the headphones will go. So if I can output clean signal with only 13mW and reach 110dBSPL, then I don't see how having big strong 800mW amp would be useful, because I can't never output that much power into the headphones. I would still only be using 13mW to drive the headphones.
