Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
Sorry, I've started a new thread because hadn't seen this.
I'm looking for a wireless headphone, and I need good isolation from outside noise.
My limit is 250 - 300 euros.
And I live in Italy.
I've seen Sennheiser RS 170 & RS 180, but these are open back.
What's the best choice?
Are you looking at wireless home or wireless portable? Here's their current lineup of options:
http://www.sennheiser.com/sennheiser/home_en.nsf/root/private_headphones_wireless-headphones
a few more in their travel line
http://www.sennheiser.com/sennheiser/home_en.nsf/root/private_headphones_travel-line
You sure?
Are they the best ??
While not a personal favourite of mine, the M50 are solid headphones.
Any ideas ppl ?
mainly i do listen to electronic music and hip hop. i'll be using whatever i buy only in font of my computer at my flat, so that means environment will be almost without any loud noises
I would say the HFi580 or Pro700, unless you're a competitive FPS gamer in which case I would pick something much lighter on bass.
Okay, thanks. Have you done the HD58 -> HD598 foam mod? Results?
Thanks
Haven't tried it myself; only know what I've read. Most consensus seems to the say the 555-->595 convert is valid, but the 558-->598 mod might still be lacking something. In either event, it's not a "huge" difference.
