derbigpr
- Jan 19, 2011
It doesn't have distinct advantages over the others, but it's not especially bad or great at anything either, except maybe bass texture and extension, yea, probably the best of all you've listed when it comes to bass. But, it's definitely not the best for jazz and acoustic, those would be HD598, HD600 and K701. It has thin and recessed mids compared to those headphones, so vocals and instruments will never sound full or very satisfying, at least in my opinion. K701 is far more enjoyable for that purpose, I can definitely say that. And HD598 is probably even more enjoyable. Now, as for metal, I don't listen to it that much, so I won't talk about it, but I'd guess again that HD598 and HD600 would be the best for that. Overall, I would not recommend you the Beyers, unless you really want a headphone that is good at everything, but not especially impressive at anything. And not to mention you DO need a proper amp for it, and if your budget is 300$, then don't even consider them. Same goes for HD600's and K701's.
Why would you recommend the Beyer? Are there any distinct advantages over the others?
As of right now I'm between the DT880 and the HE-300.
What amps are recommended for these headphones?
Thanks for the help!
