fjrabon
- Feb 1, 2009
How do the teak cups affect the midrange?
Much more midrange than the Mahogany/rosewood/ebony.
Yeah, the only cups I've seen make a night and day difference are the EMU teak cups. Because those have a completely different shaped inner cup cavity, it's much thinner and sculpted than all the other wood cups, which all seem to have the same basic cup dimensions.
So then Lawton cups must have made a huge different ?
Hello guys.
I need to make a quick decision.
I was offered a massdrop can thx00 by fostex.
If like to know which sounds better the fostex or the audeze sine.
Ill be making a purchase this week.
And this two are the only choices i have.
Pls help.
Is there anyone who can fit Audeze sockets in the TH-X00 cups/frames?
There is no better/worse/winner/loser -- they're both fantastic headphones. You're approaching the decision the wrong way and will just run in circles here.
Instead, think about how you're going to use it (at home/stationary or lots of travel/portability)...what sort of source you're playing from (DAP, laptop, amp/dac, iDevice in case you ever want to spring for Cipher cable) and what sort of music you like (and sound signature you're after).
See the post by @brent75 above. To add a little to what brent75 said above I would say that they are headphones designed for different situations and only you can decide which is "better" because none of us can say what sound you like.
If you will be using it for going out then I think getting the Audeze Sine is the best choice here, unless you can get used to the TH-X00's 10 feet 'vacuum' cable (which I doubt anyone would)!ill be using it at home and sometimes when going out.
im using fiio x3ii as transport to the mojo.
in general, im usually listening to all kind of music but not metal, edm.
more on slow phased music such as blues, jazz, some rock and pop, old and classical musics too.
thanks.
ill be using it for casual listening only. at home and when going out.
thanks.
thanks.
Thanks for the quick response!
1 last question, how does the ebony affect the midrange compared to the mahogany? (This is the question i actually meant to ask, I wrote teak accidentally)
