I'll let you know soon
They should be arriving today, and I plan to spend a considerable time with them tomorrow. I've also scheduled to get together with a couple guys locally. One has a pair of un-modded 900's and a Unison Research amp that has 2 single ended outputs - pretty easy to do direct A/B comparison. I'll also be taking my AURALiC Aries/Vega/Taurus so I can hear both cans on my set up.
To my ears, the TH900 was not in the same league as HD-800 and HE-6. Besides the V-shape sound masking the mids, there is a clear sense of unnaturalness with respect to the soundstage. Perhaps limited by the closed back design, I felt the peripheral soundstage was abruptly intercepted and distorted as there was a dome-like spherical wall blocking the expansion of the soundstage.
I think that my modded TH900 does not have the soundstage limitation, at least not to this extent.
It's true that my modded Stax 007 has better stage, and so does the HD800, and perhaps even the HE-6, albeit that is a close call, and I agree that even the modded TH900 may not be as good/neutral/revealing as the HD800 and HE-6 when they are properly driven, but:
- I don't feel like having a distorting wall; when sounds seem coming from a far distance with the 007, they do so with the TH900 as well, albeit closer. The carbon foam pad filling helps a lot with soundstage. If you care more about sound stage than mids, you can try using the original dampers (the grey foam ring around the drivers) rather than the felt dampers. The felt dampers can overdamp easily, and every cutout will likely sound different anyway, it's so sensitive to minor and micro-variations, and then every felt sounds different, even from the same felt sheet when cut from different parts of the sheet.
- the main strength of the TH900 is still that it is a closed design, and that's exactly what I need most in it in the office, or when watching late night movies at high volume
- it works wonderfully with portable DAC's, and while it does scale with good amps, I get most of the goods right at the start of the range, from a Resonessence Herus, or even a Sony Z3 phone
- the modded TH900 is fun, and for me much more fun, with better stage, mids, bass and treble than the non-modded TH900
However, when in the evening I put on the 007 (not so much the 009 nowadays), I melt away.
So that's the context, and I have made peace that after a year of tweaking, I have seemingly reached the "good-enough" limits of the TH900, and it is what it is and no more
I will notify this forum when I find a better closed headphone for the above purpose (the LCD-XC is not, at least for me, although I did not try to tweak that one).
