attmci
the problems with multiple parallel output tubes as i see it are:
a) the grids can interact with each other very easily. to isolate them, you can install grid stoppers for each tube, but this can also lead to other problems, described in c) below...
b) there is some merit to the long held hifi belief that a single tube sounds clearer than multiple parallel tubes. this has to do with the impossibility of having an exactly matched pair of tubes. as a result, the tubes will "fight" each other to some extent as to what exactly the output SHOULD be at any given instant. folks have said the parallel tube tends to defocus the sound when compared to the single tube.
c) including those grid stoppers described in a) can actually exacerbate the problem, since now the electrode voltages will be dependent on the electrode CURRENTS.
