3083joe
- Apr 25, 2014
Try mixing the flat plates with x plates on dual adapter!
The whole thing of mixing different power tubes is a different ball game. Cannot figure out what will work well or not, so I am just trying various combinations, using what I have sitting around - trial and error. It could also be that the tube combination is specific to the amp you are using.
At the moment I only have dual power adapters and not triple.
Using EL3N as drivers: What works well for me are the 6N7 and 6N7G tubes together with the 6BL7.
Tried using the 6N7GT tube, which should be the same as the the 6N7 and 6N7G, but it did not pair well.
Tried the well regarded 6N23P (6DJ8 family) and the 6H6p - forget it; very bad hum.
All the above tubes are together less than 2.5A so present no problems for an amp designed for one pair of 6AS7/6080.
The 6BL7 and 6N7 combination is delicious and certainly suits my frugal nature - paid less $3 each for my 1943/43 6N7 tubes. Even the ECC31 to 6SN7 adapters are available at a low price from Suzier. ($13.16 for a pair incl shipping)
Can just one 6N7 be used in the Woo WA22 power socket?
Excellent. I will give it a go then. Much difference in gain? Say between a 6AS7G?
I've got plenty of scope. Highest I ever get is 11'Oclock.
The 6N7 (6N7 = metal can, 6N7G = glass coke bottle, 6N7GT = straight-sided glass bottle) has an amplification factor of 35. And the heater draws 0.8 amps.
The 6BL7GT has an amplification factor of 15.
And the 6AS7 has an amplification factor of 2.
Also, for comparison, it is 20 for a 6SN7 and 33 for a 6DJ8.
As always, YMMV - different amps and different equipment may sound different with the same tube.
I did not care too much about the 6N7 as a single tube, but together with the 6BL7 it makes my amp sing. Again, I am using my amp as a preamp and listening through speakers, and not headphones.
As a driver? Or as an output tube? I certainly don't know but I suspect that it likely depends on how similar the Elise and WA22 are...
The EL3N is a single pentode. So the adapter must convert the pentode into a single triode, and then redirect the pins to allow it to operate in a double triode circuit. This is very similar to how a pair of C3g is used (as drivers) in the Elise...
Yeah. I feel like someone here has been using them. Or on the woo audio thread.
