is anyway you can post the presets of this wizard? 37904/foobar2000.v1.2.2.Dolby.Headphone-RPGWiZaRD/foobar2000.v1.2.2.Dolby.Headphone.%28Forward%29-RPGWiZaRD.fbcp
the links on the front doesn't work
ok thanks i think just look for the .fbcp file
thanks again
Can anyone help me with dsp chain serialization? The whole hydrogenaudio site is down. Im just want to load the fbpc files!!
Thanks
OK here's a link to a preconfigured "Neutral" preset. As usual it comes with the forward and laid-back configs as well and you can check the OP to see how to switch between them:
Portable preconfigured foobar2000 install in otherwise factory state:
foobar2000 v1.3.13 Dolby Headphone (Neutral)
Or if you prefer to load the config to your current foobar2000 setup using the DSP chain serializer plugin (check first post how to do that):
foobar2000 v1.3.13 Dolby Headphone (Neutral) .fbcp
foobar2000 v1.3.13 Dolby Headphone (Forward) .fbcp
foobar2000 v1.3.13 Dolby Headphone (Laid-back) .fbcp
The opening post should be updated at some point but I'm too lazy for it right now at least. As usual it's a full portable install foobar2000 with only the plugins included that this config is utilizing besides the standard ones and foobar2000 in a factory default state. You might have to manually load the dolbyhph.dll file even though I have checked the box to ignore the foobar2000 dir's install path, if the volume is rather low then the dolbyhph.dll is probably not loaded.
