- Dec 30, 2013
Do others agree that configuration sounds similar to FitEar333?
which config mate
I just tried the combo and to me it sounds like a livelier and more dynamic version of ER4S. Not sure if the FitEar333 sound leans towards this direction.
The only FitEar333 I've heard is TG334, and clear-clear-green is quite different - leaner + sharper.
What @audio123 said, the Private333 is different from the 334.
From my memory of the time I auditioned it, the 333 has a nice and quick bass which only shows itself when it needs to. It also has crystal clear mids and highs. If I would use one word to describe the 333 sound sig, it would be that it is very "clean".
Really sorry if this isn't so helpful in describing it. Kinda new to describing sound. But to my ears it definitely sounds similar.
333 has great extension and transparent. 334 is sweet sounding.
Ah yes. That was the word I was looking for. Transparent. Thanks!
i can see from your profile u frequent LMUE often
Haha that's right! Pretty much half of my current inventory was bought from them.
LMUE is pretty much the place I first recommend people to go to when they want to buy new iems. Most of the best bang-for-your-buck iems can be found there. Heck, when my sister's pair of Audio Tech broke, I brought her to LMUE to try out the D2 and she bought it on the spot.
Its position has one demerit though. Right after I bought the FLC8S, my friend whisked me away to Jaben just downstairs from it and told me to try the 333, telling me I'll like it.
What a mistake that was, especially after purchasing the FLC8S. Now I'm counting down to the day where I can get a pair.
Unless Celeste blows it out of the water of course. Then the Celeste will be my choice of upgrade.
lmue service is just 11/10
