somestranger26
- Dec 6, 2007
Well I am outgrowing my 1.5TB drive because I have >300GB of music since I have a copy in both FLAC and WMA Lossless, so no, hard drive space is not magically irrelevant since it's cheap. Computing power saved by using a lower compression level is LAUGHABLE. Your CPU sure is being stressed when it's being utilized 1%...
Originally Posted by stokitw /img/forum/go_quote.gif You probably don't want to compress the file in the highest level. The size of storage grows so fast in these days, the marginal benefit of highest level of compression simply does not worth it. You want to save the computing power as much as you can, so playback on either PC or portable device can be easy. |
