First photo of E17
- Home
- Forums
- Head-Fi Special Forums
- Premier Sponsor Forums and Sponsor Forums
- FiiO
mRfRag
- Apr 28, 2011
Looks sexy, great job Fiio!!
Parall3l
lƐllɐɹɐԀ
- May 21, 2011
Ikelmonster
- Jun 13, 2011
Looks great, I am interested to see how big it is compared to the E7, not that it will effect my purchase, I've been holding out for an E7 because of this coming out and don't intend on changing my mind
Allforheather
- Nov 13, 2010
SQ and more feature.
SQ: 96/24t@USB 192/24@coax/optical , better amp
Feature: more input, balance, bass&treble, gain switcher, hardware hold switcher.
You'd mentioned coax/optical input, will the connection be natively on the e17 (highly doubt it) or will there be a special adapter for it?? And can I use coax/optical input when e17 is docked on the e9??? I'm really happy about fiio bring optical/coax input to the e17, but kind of confused how it is implemented.
飞傲加油!!
Greetings from a fellow countryman
JoetheArachnid
- May 10, 2010
Both coax and optical can be done through a 3.5mm socket, so I don't see why there should be a problem with connecting things. Special cables may be necessary for the optical though.
bcasey25raptor
Aka: Brycon Casey
aka mental patient
aka Enter Darkness
aka Shurefan
aka reaperofaudio
aka everyone knows
aka very funny
- Dec 28, 2010
How much is this going to be? I am interested.
hotsport
- Feb 13, 2009
in our roadmap, E7+E9 is different kind of product with E17, as you can have a low at below, the sequency is depend on price from low to high
1, E7: Portable USB DAC+AMP, USB 16BIT/48K US$100 (reference)
2, E9: Desktop AMP US$120 (reference)
3, E17: Portable USB DAC+AMP, USB 24BIT/96K, Optical/Coaxial 24BIT/128K US$190 (reference)
4, E7+E9: COMBO US$190 (reference)
5, E15: Desktop USB DAC+AMP, USB 24BIT/96K, Optical/Coaxial 24BIT/128K US$290 (reference)
6, E17+E9: COMBO US$290 (reference)
So you can choose the best solution for yourself.
We may use the different DAC in E17 and E15 because some DAC need more power so it is not suitable in portable device. if compare with the combo of E17+E9 with E15, you will find that
Or you get the best DAC or you get two device that is more flexible.
From here http://www.head-fi.org/t/536552/fiio-e17-speculations/45
putente
- Nov 10, 2010
This E17 will cost $190?!?
Riku540
- Sep 30, 2005
Name another 96kHz/24bit battery powered portable DAC/Amp (and a real working amp section at that) for less.
Ikelmonster
- Jun 13, 2011
Also, notice those reference prices are from March. The price could go up or down a bit. for example, the E7 on that comparison is priced at $100 but I've seen it around $85 for a while now
putente
- Nov 10, 2010
I see, but in my case (and I believe it's the case of a large number of users) I just use the E7 together with the E9 (same for the E17, if I'd buy it). The portable part of it doesn't mean anything to me. Maybe it would be a good idea if Fiio launched a "chopped" version of this E17, without the amp+battery part, and that way it could be a lot cheaper, and would make more sence to use with the E9. Just my 2 cents...
Riku540
- Sep 30, 2005
... They did. It's called the E10. ($80)
It may not dock, but you can set it on top of the E9 and it'll cover up the dock and look like a nice DAC sitting on top of an amp.
putente
- Nov 10, 2010
You're almost right, if the E10 had an RCA/jack input, where I could plug my CD player (which I do on my E9). Since it's not possible, I'll have to stick with an E10 (I'm seriously thinking in buying one as soon as it gets to Europe) and maintain the E9 just for the CD player (and probably selling the E7, since it becomes pointless while having the E10 at the same time)...
The E10 would be perfect for me with that RCA/jack input!
Riku540
- Sep 30, 2005
The thing is, they already offer two portable DAC/Amps that support analog input: the E7 and E17. One is $85, the other is about $190, with a large performance gap between them.
The E10 by design is a completely different package as it offers a minimalist design to offer a better transportable DAC for those who do not need a completely portable solution. Not only is an analog input unnecessary for a DAC, having it would add to the cost. They have the E11, which is there for those who want a portable analog input, and of course, the E9 as a desktop solution.
What I'm saying is, they basically have a product for just about every possible combination of scenarios you could possibly ask for. How much more flexibility do you want?
You already have the E7+E9... is that not good enough?
Unless you need the 96kHz/24bit, there's really no reason to upgrade from the E7 unless you simply aren't satisfied with it. If that's the case, well... you can't have everything.
Bottom line is, FiiO offers a product for all levels; low - Hi-Fi. All are priced accordingly and competitively lower than most competing brands.
The $190 price tag for the E17 is justified to me.
- Home
- Forums
- FiiO
