FiiO X5 firmware 2.4 download and discussion
Jan 10, 2015 at 7:51 AM Post #32 of 209
Ok, I had to hold the shortcus button, press reset and keep holding the shortcuts button until something happens. And it did. Updated my firmware correctly, everything is ok now. Thanks!
Was that a reply from FiiO or did you work it out from some other source? Just interested because if it was from FiiO it appears they answer emails pretty damn quick compared with other support areas I have encountered.
See post # 26 (above) - Joe Bloggs replied to pw55255
And Joe Bloggs is indeed a FiiO official. Just sayin' :cool:
Jan 10, 2015 at 8:16 AM Post #33 of 209
Hi,
After updating from 2.2 to 2.4, playback of large FLAC files with CUE sheet have occasional hiccups when a track changes to the next one. Anybody else noticed that?
Jan 10, 2015 at 9:03 AM Post #35 of 209
Hi.
Thanks for the firmware update. The 5800 library limit is not foxed for me with this firmware. The library scans to 6911 and then the X5 freezes. I have around 30,000 songs across 2 128gb SD cards.
Is there any fix for this?
Thanks, Paul.
Jan 10, 2015 at 10:00 AM Post #36 of 209
Oops, didn't notice it was your reply Joe. Thought pw55255 had tried your solution and it failed from his reply but I should have kept quiet till it was sorted out by you :)
Jan 10, 2015 at 11:15 AM Post #37 of 209
HELLO JOE BLOGGS AND FIIO DEVELOPERS! Thank you for releasing new firmwares for Fiio X5! Fiio is getting better and better. I have carefully tested new X5 FW2.4 firmware and found many bugs and interface inaccuracy. I hope it’s not a problem for you to fix all of them. I also have some suggestions how to make X5 even better. Joe, can you please comment my suggestions?
Bugs I’ve found in X5 FW2.4:
1. When I open folder with cue sheet and wav file it doesn’t show the album title from cue sheet on main display. Instead it shows “Unknown album”. When I open folder with cue sheet and flac file it doesn’t show the album title from cue sheet on main display. Instead it shows album title from flac file. I suggest when playing cue sheets albums (wav, flac, ape) to always show the album title from cue sheet. The same for track title and performer – always show it from cue sheet. If there is no track performer, show album performer from cue sheet. If there is no track title in cue file, show track number (Track 01, Track 02, Track 03). In FW2.4 if there is no track title in cue file it shows album title from cue sheet instead.
2. When I open folder with file in format wav (176.4 kHz / 24 bit, file size is 2.5 Gb) it doesn’t play and says “File format not supported”. I have a lot of live recordings that are larger than 2 Gb and they all doesn’t play.
3. When I play some flac albums in folder (bitrate 1100, compression 8) and change to next track it plays immediately but change the name of the track and file info too slowly, about 1-2 seconds (For example album “Dave Koz – Hello Tomorrow / 44.1 kHz 16 bit Flac)
4. When I play folder with cue sheet something is wrong when FiiO X5 change to next track. The first second of each track stutters. I’ve tested it on every album and its very annoying. On FW2.2 everything is ok.
Cosmetical enhancements:
5. In System settings - About X5 – “TF card 1 total capacity: 29.5 G” it’s better to change  to “TF card 1 total capacity: 29.5 Gb”. The other lines change the same way
6. In System settings - About X5 – “Total no. of songs: 1500songs” it’s better to change  to “Total number of songs: 1500” or “Total number of songs: 1500 songs” (with space after number 1500)
7. In System settings – Key-lock settings – “Lockscreen 1” there is no indent at the left side. I suggest to rename it to “Mode 1”, “Mode 2”, “Mode 3” to fit them nice
8. In System settings – USB mode “Storage / DAC” I suggest to align to right word “Storage” without space after it, like the “>” aligned to right to make it look better. The same in “Play settings – Resume mode – Last position”, “Power-on volume – Last setting”, make it all aligned to right without space at the right
9. On the main display I suggest to add a space between 44.1, kHz, / , 16 in “44.1 kHz / 16 bit”
10. I suggest adding a folder icon “Play through folders” in shortcuts and in “Play settings – Play mode” instead of a menu item “Play through folders - On/Off”.
When I want to “repeat only one folder” or “play one folder and stop” I have to change Play mode and after that go to “Play settings” and switch off “Play through folders”. It’s very inconvenient. It’s better to change play mode in shortcuts or in “Play settings – Play mode”
11. When I open folder with cue sheet it show track numbers this way: “Track01.WAVE”, “Track01.WAVE”, “Track01.WAVE”… even if the music file is in Flac or Ape format. It always shows “.WAVE”. I suggest to show the extension of original file format (Track01.wav, Track01.flac, Track01.ape). And to better understand that I opened folder with cue sheet I suggest to change the “folder icon / folder name” at the top of the list to “cue sheet icon / folder name”
12. When I open folder, then playlist in it, the font changes to small. It looks not so good. I suggest to open playlist the same way like it is a folder, but change a “folder icon / folder name” at the top of list to “playlist icon / playlist name”
13. In “Play settings – File name display – Track name display” I suggest to change to “Track title display – Track title / File name”
14. I suggest to rename “EQ:OFF” to “EQ:Off” at the top and in EQ menu. So it will look the same way like “EQ:Rock”, “EQ:Jazz”…
15. When I go “Play by category – Artist – All songs” it sorts and play all tracks by the artist alphabetically. I suggest to sort them in original album order so that it plays first album in original order, then second album and so on. Now it’s very inconvenient because if I have 5 albums with track named “01. Track name 1”, “02. Track name 2”, “03. Track name 3”, “04. Track name 4” and play All albums by Artist it always play first track of each album, then second track of each album and so on. It’s not interesting to listen in such order. Maybe it’s better to have an option in menu “Play all albums by artist – Album order / Alphabetical order”
Wishes to improve FiiO X5:
16. It will be very useful if you make equalizer work for any files 88.2, 96, 176.4, 192 kHz. Now it only works for 44.1 kHz.
17. It will be very useful if you make native DSD playback. Now when I play dsd files FiiO X5 always converts them to 88.4 kHz and in my opinion it sounds not so good as the same album converted on computer from DSD to PCM 176.4 kHz and played on FiiO X5. From digital output it would be nice to have a choice in menu to output in “DSD over PCM format”, or in converted to 176.4 kHz.
18. It will be very useful if you add an option in menu “Fast Roll-Off / Slow Roll-Off” to change digital filter mode of PCM1792. The same option has added the iBasso to DX90, and I very like to listen on DX90 in “Slow Roll-Off mode” most of the classical and jazz music. For now FiiO X5 only work in default PCM1792 “Fast Roll-Off digital filter mode” and doesn’t have an option to change it
19. In Play settings I suggest to add an option “Album art – On/Off” to enable or disable showing album art
20. In “Play settings” I suggest to add an option “Playlists – On/Off” to enable or disable showing playlists in folders
21. It will be very useful if you add in menu an option “Show Battery in percent – On / Off”.
Jan 12, 2015 at 6:38 AM Post #41 of 209
is it me only...i think the ramdomize all song is back to the old issue....only a few tracks is being play out of my whole library.... :frowning2:
what really happen? :frowning2:
There's always 2.36beta to fall back on...
I think we should call 2.36 the stable and 2.40 the beta :confused: :confused: :frowning2:
