FiiO Mont Blanc/E12 portable headphone amp, 880mW, slim design, full metal case. Bass boost and Cross feed!
Sep 15, 2013 at 12:17 AM Post #2,236 of 3,739
If it's any consolation, I really like the bass boost on the newer E12. Isn't it aimed at 50hz? That's not too high up.
http://www.fiio.com.cn/products/index.aspx?ID=100000038732625&MenuID=105026001
Fiio's official spec says +4.2db at 100Hz , which I assume is what the newer batch does. Based on Fiio's graph, bass boost before 100 Hz should be even higher than +4.2 db.
However, Fiio's graph might not be updated to reflect batch 2 bass boost (it is contradictory to spec's +4.2db@100Hz). It shows a +2db@100Hz, which seems to be that of batch 1 bass boost.
ClieOS measured a batch 1 bass boost here and showed a graph similar to Fiio's: http://www.inearmatters.net/2013/03/impression-fiio-e12-mont-blanc-way-to.html?m=1
ClieOS also indicated that batch 2 bass boost will be broader and less deep/tight.
Sep 15, 2013 at 12:18 AM Post #2,237 of 3,739
Yeah, it's not that high. Subwoofers usually crossover (in?) at around 80-100 Hz depending on personal settings in a home theater, for reference. I haven't heard the new E12, and while I stick to liking what I'm hearing, I doubt that they're Really changed. Lets try it from this angle... Anyone with a current E12, have you noticed that turning on the bass boost over did it for a particular song compared to "off?"
Sep 15, 2013 at 12:34 AM Post #2,239 of 3,739
I don't like the bass boost all that much...it seems to bleed into the midrange and raises the overall volume level.
I don't like bass boost bleeding into mid range either, which is why I prefer boost to subside before 100Hz (if I have to use boost). Your batch 2's boost bleeds a lot more than that of batch one.
Sep 15, 2013 at 1:21 AM Post #2,240 of 3,739
It depends on what headphone is used. I liked it with the MA900 on bass light music, but not bass heavy music (which the MA900 sounds fine at default). I hated the bass boost with the X1, but that's because the bass is already quite prominent.
Sep 15, 2013 at 2:01 AM Post #2,241 of 3,739
I love the bass boost with my X1's, but that's possibly due to having batch 16 :wink:
Sep 16, 2013 at 4:01 AM Post #2,243 of 3,739
Heh, i got so used to E12 in my setup, that today when amps battery unexpectedly died I was just completely stunned by how bad it actually sounded without it :-D
Sep 16, 2013 at 12:13 PM Post #2,244 of 3,739
If there is ever a successor to the E12 it would be nice if it employed a DC servo so it would get around having to use coupling caps (I am presuming that is what the two 2.2uF polyester caps are)
Sep 16, 2013 at 12:20 PM Post #2,245 of 3,739
That's awfully small for output coupling caps!
They are Probably power supply bypass caps for noise suppression..
Sep 16, 2013 at 12:38 PM Post #2,246 of 3,739
Good point, I should have caught that
Actually I think they may be inter-stage coupling caps. 2.2uF is about right for that.
Maybe James will comment.
Sep 16, 2013 at 6:05 PM Post #2,248 of 3,739
Fiio says 50hz V1 20hz
I think you are referring to the bass boost.
Here's a link to the FR graphs that James provided earlier relating to the initial batch's bass boost versus how it was going to be (and how it was) changed:
http://www.head-fi.org/t/620339/fiio-flagship-portable-amp-mont-blanc-e12-discussing-thread-the-pre-order-unit-arrives/1005#post_9132609
Sep 16, 2013 at 6:22 PM Post #2,250 of 3,739
And this confirms what folks are saying. The knee frequency has gone up by almost an octave.
