FiiO M23, AK4191EQ+AK4499EX, THX AAA-78+, Dual Type-C Ports, Dual-Core Fast Charging, 1000mW+1000mW @32Ω
Mar 18, 2024 at 1:50 PM Post #32 of 365
i thought android 12 has cancelled bit perfect?
What do you mean ? Android does not have bit-perfect audio in any versions, not even 14 (only USB audio).
Chi-fi brands like Fiio have always implemented their own Android resampling bypass. In other words this player has bit-perfect audio, no matter which Android version it is using.
Mar 19, 2024 at 7:14 AM Post #34 of 365
Mar 19, 2024 at 7:15 AM Post #35 of 365
I think you also own and use the HiBy R6 Pro II so I'd like to ask you, by looking at their specs, would you consider the M23 a much better device?
"Looking at specs" never goes well
Mar 19, 2024 at 7:20 AM Post #36 of 365
Mar 19, 2024 at 7:53 AM Post #37 of 365
Yes I have the R6 Pro II. Well, let’s see how it looks on paper.
R6P2
- R6P2 has 2x AK4499EX DACs. M23 has 1
- Dedicated LO ports (if that matters)
- Superior Software
M23
- Desktop Mode (For most people this is not needed. A DAP is meant to be used as a portable device, not plugged into power all the time)
- Has more power for those power hungry headphones
- Fast charging (faster than the R6P2)
Common
- Same CPU
- Same RAM
- R6P2 has Android 12. M23 will initially ship with Android 10 and upgraded later to 12
- Both has Class A amps
- Same battery life (slightly higher on M23 but not so much to list it as an advantage)
- Same price ( R6P2 might be available slightly cheaper )
We don’t know the full specifications of M23 yet. However from what we know so far on paper, I would go for the R6P2, mainly due to the dual AK4499EX. In the end, to each their own.
Given that, I’m curious to try out this DAP. I haven’t had a Fiio DAP for a long time now and I’m curious to see what they have been cooking under the hood.
Mar 19, 2024 at 10:05 AM Post #38 of 365
i must have been sleeping and ran out of memory. Its the other way around! Android 14 gains bit perfect support: https://www.audiosciencereview.com/...roid-14-supports-bit-perfect-usb-audio.44675/
Sorry for the confusion once again!
Mar 19, 2024 at 11:44 AM Post #39 of 365
R6P2
- Superior Software
M23
Common
- Same CPU
- Same RAM
Here is how I have it from what I've gathered, so far :)
Mar 19, 2024 at 12:27 PM Post #40 of 365
Mar 19, 2024 at 7:26 PM Post #41 of 365
Mar 20, 2024 at 1:22 AM Post #42 of 365
Android 14 has bit perfect capability, but only via USB. In other words, by connecting your Android device to a USB DAC you will have bit perfect with Android 14.
Source: https://www.reddit.com/user/google/...=web3xcss&utm_term=1&utm_content=share_button
No, it doesn't support with USB for all apps. It works only with apps supporting USB Exclusive mode and for this Android 14 is not required, many older versions support bit perfect on USB Exclusive mode. For example UAPP and Neutron player. However, streaming apps like Apple music doesn't support bit perfect on Android 14 even with usb mode.
Mar 20, 2024 at 8:10 AM Post #44 of 365
