FiiO M23, AK4191EQ+AK4499EX, THX AAA-78+, Dual Type-C Ports, Dual-Core Fast Charging, 1000mW+1000mW @32Ω
May 11, 2024 at 11:03 AM Post #301 of 380
just got my m23, updated the firmware straight away, and then have a first listen, the sound is really good!
one wierd thing though about the desktop mode:
with desktop mode switch 'on'
1. when connecting QC3.0 charger thru the orange power usb socket, the desktop mode notification appears only as text on near the bottom of the screen, yet there are only 3 choices of gains: low mid high, on the gain selection
2. only when connecting thru the black usb socket, the blue notification box appears and the super high option appears on the gain selection, total 4 gains selection.
is this normal behaviour?
dear @FiiO , please kindly check, thanks
May 11, 2024 at 9:51 PM Post #303 of 380
yes, it is normal.
May 11, 2024 at 10:59 PM Post #304 of 380
"Smooth, laid back, flat, sound thin"
Everything that i hate. If it's really like that, then as soon as I receive it, I'll send it the f__ng back to China
https://headfonics.com/fiio-m23-review/
https://www.head-fi.org/showcase/fiio-m23.27179/reviews
That hasn’t been my experience at all. If anything, I’ve found that it has more punch than my desktop stack. With that said, I’m only using IEMs with this DAP so I can’t vouch for its performance with full-sized headphones.
May 11, 2024 at 11:00 PM Post #305 of 380
May 12, 2024 at 2:03 AM Post #306 of 380
May 12, 2024 at 11:18 PM Post #308 of 380
Dear friend,
Hi,
The POWER IN port(orange power usb socket) only supports PD2.0/3.0 fast charging, while other types are recognized as normal charging. Your charger may not support PD2.0/3.0 fast charging, so fast charging is not working and super high gain option is not shown in the gain option when connecting the same charger to power in port.
Best regards
May 13, 2024 at 12:38 AM Post #309 of 380
Dear friend,
Hi,
Best regards
thank you very much. that explains it, yes correct my charger only support qc3.0(no PD charging), fortunately the desktop mode still works though. the battery is not draining while using the m23 even though only QC3.0 is plugged in on the POWER IN port. all good.
May 13, 2024 at 2:37 AM Post #311 of 380
FIIO M23 By: 进击的佬八
May 13, 2024 at 3:54 AM Post #312 of 380
So far I have tested 4 units of M23 (two at Canjam SG - alu and SS, my personal unit, and a friend's unit), they all do not exhibit the issue described in the video. I doubt it is a widespread issue, but I'd be interested to know what's the cause though.
May 13, 2024 at 9:32 AM Post #313 of 380
Hello guys.
I just received my m23. The plan was to replace my Fiio M15s because of the issue I have with my new desktop amp : I can no longer use the desktop mode AND send music files to my external Amp/DAP with an usbc splitter.
So the M23 is working as expected with its double usbc. Now I can use desktop and also send music. Great!
Only one thing : with the m15s, I had the control of the volume while sending the files to the Amp/DAC. Now I can’t with the m23. Volume is the same whatever volume I have on the m23. And it was not the plan 😅
Any idea @FiiO ? An option to activate maybe?
May 13, 2024 at 9:38 AM Post #314 of 380
Hello guys.
Can you compare the m23 and the m15s sound wise ? Downgrade or sidegrade ?
